Thanks for your reply.Welcome to AAC!
Have you given the current source a finite resistance?
Have you tried making the two PMOS devices slightly different rather than identical?
Thank you.The source of a timestep error in Spice can be hard to pinpoint.
Sometimes just a small change in the circuit will eliminate the problem.
Try removing part of the circuit at a time to see if you can determine, which area is the problem.
Also you might go into the Spice transient simulation values and try reducing some of the default accuracy parameters by a factor of 10 (shown below in the righthand column from LTspice).
If you can change the default integration method to Gear, that also sometimes helps.
I'm not familiar with Proteus, but I would think it uses a Spice engine with Spice simulation parameters.Thank you.
But I simulated the circuit in proteus not spice, how can we change transient simulation values in proteus?
Try adding, say, 1 milliOhm in series with the emitter of one (only one) of the transistors forming the current mirror. The intention is to avoid exact symmetry so that Spice/Proteus isn't trying to assign two values to the same node at exactly the same instant (as far as I understand the machinations of Spice ..... which could be way off ).I don't know how to change transistor properties in proteus.
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Aaron Carman
