Timer Suggestions Needed
gregeeh
Joined Oct 19, 2021
32
Hi all,
I require a simple cct that will activate a small relay for 5 secs 2 secs after power is applied to the circuit. Maybe a 555?
TIA
Greg
MrSalts
Joined Apr 2, 2020
2,767
The PNP transistor discharges the capacitor when the switch is opened (the timer is turned off. It is important to discharge the cap so you get the same 5 seconds of delay after each switch throw that powers up the 555. The 555 can directly drive many relay coils if you have a 5 or 12 v coil under 200mA.
38,870
Below is the LTspice simulation of a circuit using one CD4093 quad 2-input Schmitt-trigger package, and an N-MOSFET driver for the relay:
The relay turns on (yellow trace) about 2s after the power turns on (green trace) and turns off about 5s after that.
38,870
I don't think that circuit will work since, if a real 555 TRIG input is held low, I believe the output will stay high.
What generated that displayed output?
gregeeh
Joined Oct 19, 2021
32
@crutschow - Thanks for your cct, it's appreciated. Could the circuit be simplified if I did not require the 2 sec delay after power is applied? ie: Apply Power | turn on relay for 5 secs | turn off relay until power removed & applied again.
Sensacell
Joined Jun 19, 2012
3,789
I love the CD4093 chip! it's my all-time favorite part in fact.
With a 4090 and a handful of resistors capacitors and diodes - you can solve almost any tricky, annoying problem.
MrSalts
Joined Apr 2, 2020
2,767
The 555 triggers on power up in mono-mode. It is a challenge to prevent the triggering on startup.
Closing the switch near Vcc causes the pulses in the image above.
I think you contributed to this thread on the 555 powering up / self-triggering
https://forum.allaboutcircuits.com/threads/555-timer-getting-triggered-on-power-up.158538/
Note: the OPs timing requirement was not perfectly clear.
38,870
Yes.
It would eliminate a resistor and capacitor on the CD4093 circuit, or allow the use of a simple 555 one-shot circuit.
If the 5 sec turn-on time is not critical, you could use a circuit with just a MOSFET (below):
When power is applied (yellow trace), the N-MOSFET's gate (red trace) is charged to 12V through the capacitor, turning on the transistor and relay (green trace).
When the capacitor discharges through R1 to below the MOSFET's turn-on gate voltage, the transistor and relay turn off.
The on-time will vary some with the particular MOSFET you use, and the tolerance of C1 and R1, so you may have to tweak the values of C1 and/or R1 to get the desired on-time.
Increasing either value will increase the on-time.
gregeeh
Joined Oct 19, 2021
32
I like this, it is really simple and will be reliable and robust. Does not have the ON delay but I believe I can live without that. Thank you once again.
Greg
38,870
If you can't, an added transistor delay will provide that (below):
Edit: Note that this and the previous circuit take no (only a small leakage) current from the supply after time-out, as both M1 and M2 are then off.
