Timer code for PIC18f to toggle led for 1 second
Qual
Joined Aug 5, 2016
48
Hi All,
I am facing issue in toggling led for 1 second using timer0,
led is connected to RB7 of PIC18f.
Though i can insert delay_ms(1000); and toggle led i wish to do it using timer and interrupt.
Here is my code :
#code
Code:
void main()
  ADCON1 = 0x0F;  // Disable Analog functions
  ANSELA=0;
  ANSELB=0;
  TRISB = 0x00;
  PORTA = 0x00;
  T0PS2_bit = 1;     // 256 prescalar
  T0PS1_bit = 1;
  T0PS0_bit = 1;
  PSA_bit    = 0;       // source from FCPU 5MHz
  T0CS_bit   = 1;       // Counter mode and
  T08BIT_bit = 1;       // 8 bit mode
  TMR0IE_bit=1;   //Enable TIMER0 Interrupt
  PEIE_bit=1;     //Enable Peripheral Interrupt
  GIE_bit=1;      //Enable INTs globally
  TMR0ON_bit=1;      //Now start the timer!
  TMR0ON_bit =  1; // Timer0 is on
TRISB = 0b01111111;  // 7 bit is output and rest are input
  while(1);             // Infinite Loop
  void InitTimer0()
  T0CON    = 0x86;
  TMR0H    = 0x67;
  TMR0L    = 0x69;
  GIE_bit    = 1;
  TMR0IE_bit    = 1;
  void Interrupt(){
  if (TMR0IF_bit){
    TMR0IF_bit = 0;
    TMR0H    = 0x67;
    TMR0L    = 0x69;
    //Enter your code here
    counter++;  //Increment Over Flow Counter
      if(counter == 76 )
         //Toggle RB7 (LED)
         if(RB7==0)
            PORTB.F7 = 1;
         else
            PORTB.F7=1;
         counter=0;  //Reset Counter
      //Clear Flag
      TMR0IF_bit=0;
#code
Any thing wrong in the code....?
Please suggest
Picbuster
Joined Dec 2, 2013
1,060
Hi All,
Here is my code :
#code
Code:
void main()
  ANSELA=0;
  ANSELB=0;
  TRISB = 0x00;
  PORTA = 0x00;
  T0PS1_bit = 1;
  T0PS0_bit = 1;
  void InitTimer0()
  T0CON    = 0x86;
  TMR0H    = 0x67;
  TMR0L    = 0x69;
  GIE_bit    = 1;
  TMR0IE_bit    = 1;
  void Interrupt(){
  if (TMR0IF_bit){
    TMR0IF_bit = 0;
    TMR0H    = 0x67;
    TMR0L    = 0x69;
      if(counter == 76 )
         //Toggle RB7 (LED)
         if(RB7==0)
            PORTB.F7 = 1;
         else
            PORTB.F7=1;
      //Clear Flag
      TMR0IF_bit=0;
#code
Please suggest
here my code to obtain seconds.(using a xtal on RC0 and RC1 32768KHz).
if (TMR1IF)
TMR1IF=0;
TMR1H=128; // in seconden
DateTime.Sec++;
// Toggel led
led = ! led;
///in main
TMR1IE=On;
TMR1IF=0;
AlbertHall
Joined Jun 4, 2014
12,637
What problem do you have with this code?
Which processor are you using?
What clock frequency?
Please include the config settings.
Qual
Joined Aug 5, 2016
48
Problem is led does not toggle. Doubt on timer settings and code written , whether it is working properly or not.
PIC18F45K50 ,
external crystal 20MHz,
using mikroC compiler.
Code in post 1 includes all settings configurations.
AlbertHall
Joined Jun 4, 2014
12,637
I suspect this code was written for a different processor.
The '45k40 timer 0 prescaler has four bits to set the value. To select 256 the value to set is '1000'.
The T0CS is three bits and should be set to '010' for Fosc/4
There are going to be many changes like this to modify the code for this processor but as I don't have the mikroc compiler I don't know the names used for the registers. You need to look at the datasheet and determine the settings you need and how to write that in mikroc code.
[EDIT] Sorry, I was looking at the wrong processor. Another reply will follow.
Qual
Joined Aug 5, 2016
48
T0CS should be '0' to increment on Fosc/4
Hi ,
I have tried with T0CS = 0; but no change, i did small change as shown below,
Code:
  void Interrupt(){
  if (TMR0IF_bit){
    TMR0IF_bit = 0;
    TMR0H    = 0x67;
    TMR0L    = 0x69;
      if(counter == 76 )
         //Toggle RB7 (LED)
        // if(RB7==0)
            PORTB.F7 = ~PORTB.F7;
      else
         PORTB.F7=0;
      //Clear Flag
      TMR0IF_bit=0;
But i see no toggle of led in hardware. (hardware is in good function)
AlbertHall
Joined Jun 4, 2014
12,637
Your new interrupt code won't work. You are clearing the counter on every pass so it will never get to 76.
  1. if(counter == 76 )
  2. {
  3. //Toggle RB7 (LED)
  4. // if(RB7==0)
  5. PORTB.F7 = ~PORTB.F7;
  6. } <= Delete this line
  7. else <= Delete this line
  8. PORTB.F7=0; <= Delete this line
  9. counter=0; //Reset Counter
  10. } <= Add this line
  11. }
Qual
Joined Aug 5, 2016
48
  2. {
  4. // if(RB7==0)
  11. }
Its working......:D:D thank you for support.
Thanks all for your support and guidance.
