ebeowulf17
- Joined Aug 12, 2014
- 3,307
The answer depends largely on your overall strategy. If you're thinking of using a microcontroller, then it can handle the brief off periods and/or polarity reversals with pretty simple code, so most versions are ok. Latching might be problematic, but the others would all be easy to interpret in code.From what I read there is also omnipolar, such as the Honeywell ss451a, and from what I understand, that would be perfect for my application.
The unipolar, bipolar, and latching ones, it seems to me, would all act the same, namely closing and opening the circuit (or turning on and off - I’m unsure about the correct wording) with the same frequency as the AC power supply switches direction, due to the magnetic field reversing polarity at that same frequency.
Whereas the omnipolar Hall effect sensor would remain “on” whenever the solenoid is activated, as it is indifferent to the polarity of the magnetic field, only turning “off” when there is no magnetic flux present at all.
Would you agree?
If you want to stick with your current schematic as closely as possible, then you'll either need some analog filtering or you'll need to do the switch to DC coils and rectifiers like Max suggested. If you go DC, then all but latching work again. If you keep the coils AC, I would think bipolar or omnipolar would be better because you'll have twice as many pulses available to filter, making the filter circuit a little easier to implement.
P.S. Gotta get back to work now, but I'll respond to the grinder question this afternoon.
