I've built this power on delay 555 circuit which works just fine.
However what i need is a timed power on delay.
That is, after switch is pressed there is a 5 sec delay,
then relay latches for 5 seconds then deactivates, ready for another switch press.
I tried using a 10 sec 555 timer before the "power on delay 555" circuit,
that is: pin 3 of the 555 timer will provide vcc to pin 8 of the "power on delay 555". seems crude i know, novice.
For some reason this cancels the timing circuit in the "power on delay 555" circuit,
load just stays on.
Any ideas, would be appreciated.
Regards,
Richard
load just stays on.
Regards,
Richard
