there seems to be some free lessons as well.I think you have to buy a Development Board in order to get the lessons.
//timer examples
//output asserted after a 30-second trigger, and stays on for 2 seconds;
//blocking
//http://forum.allaboutcircuits.com/threads/time-delay-on-with-2-second-pulse-output-diagram.126929/
//fuse settings
//configuration bits for 12f675 - internal oscillator (4Mhz)
#pragma config BOREN = OFF
#pragma config CPD = OFF
#pragma config FOSC = INTRCIO
#pragma config MCLRE = OFF
#pragma config WDTE = OFF
#pragma config CP = OFF
#pragma config PWRTE = OFF
//end fuse configuration
#include <xc.h> //we use xc8 compiler
//hardware configuration
#define TRG_PORT GPIO
#define TRG_DDR TRISIO
#define TRG (1<<0) //trigger input pin
#define TRG_DUR 30 //trigger duration, in TRG_PR
#define TRG_ON 5 //on duration, in TRG_PR
#define TRG_PR 10 //timer unit, in ms
#define TRG_ACTIVE() IO_GET(TRG_PORT, TRG) //input is on, active high
#define OUT_PORT GPIO
#define OUT_DDR TRISIO
#define OUT (1<<1) //output pin(s)
#define OUT_OFF() IO_CLR(OUT_PORT, OUT) //output is active high
#define OUT_ON() IO_SET(OUT_PORT, OUT)
#define DLY_1ms 65 //delay for 1ms - compiler / mode specific
//end hardware configuration
//global defines
#define IO_SET(port, pins) port |= (pins)
#define IO_CLR(port, pins) port &=~(pins)
#define IO_FLP(port, pins) port ^= (pins)
#define IO_GET(port, pins) ((port) & (pins))
#define IO_OUT(port, pins) IO_CLR(port, pins)
#define IO_IN(port, pins) IO_SET(port, pins)
//#define NOP() nop()
//global variables
int trg_cnt=0;
//initialize the timer
void tmr_init(void) {
IO_IN(TRG_DDR, TRG); //TRG as input
OUT_OFF(); IO_OUT(OUT_DDR, OUT); //turn off output, as output
trg_cnt=0; //initialize trigger counter
//delay
void delay(unsigned int dly) {
while (dly--) NOP();
//delay ms
void delay_ms(unsigned int ms) {
while (ms--) delay(DLY_1ms); //waste time
//reset the mcu
void mcu_init(void) {
//initiation code
//specific to 12f675
CMCON = 0x07; //turn off analog comparator
ANSEL = 0x00; //all pins gpio
void main(void) {
mcu_init();
tmr_init();
while (1) {
delay_ms(TRG_PR); //waste some time
//IO_FLP(OUT_PORT, OUT); //flip output pin - for debugging
//scan the trigger input
if (TRG_ACTIVE()) trg_cnt+=1; //increment trg_count if trg is active
else trg_cnt=0; //otherwise, reset trg_counter
//test to see if trigger has been asserted
if (trg_cnt>=TRG_DUR) { //trg remained on long-enough
OUT_ON(); //turn on the output
trg_cnt = TRG_ON; //reuse trg counter
while (trg_cnt--) delay_ms(TRG_PR); //keep the output on for enough time, and blocking the trigger input
OUT_OFF(); //turn off the ouptut
trg_cnt = 0; //reset trg counter
return;
here is what I put together quickly, based on my understanding of your tasks.
It runs on a 12f675.Code://timer examples //output asserted after a 30-second trigger, and stays on for 2 seconds; //blocking //http://forum.allaboutcircuits.com/threads/time-delay-on-with-2-second-pulse-output-diagram.126929/ //fuse settings //configuration bits for 12f675 - internal oscillator (4Mhz) #pragma config BOREN = OFF #pragma config CPD = OFF #pragma config FOSC = INTRCIO #pragma config MCLRE = OFF #pragma config WDTE = OFF #pragma config CP = OFF #pragma config PWRTE = OFF //end fuse configuration #include <xc.h> //we use xc8 compiler //hardware configuration #define TRG_PORT GPIO #define TRG_DDR TRISIO #define TRG (1<<0) //trigger input pin #define TRG_DUR 30 //trigger duration, in TRG_PR #define TRG_ON 5 //on duration, in TRG_PR #define TRG_PR 10 //timer unit, in ms #define TRG_ACTIVE() IO_GET(TRG_PORT, TRG) //input is on, active high #define OUT_PORT GPIO #define OUT_DDR TRISIO #define OUT (1<<1) //output pin(s) #define OUT_OFF() IO_CLR(OUT_PORT, OUT) //output is active high #define OUT_ON() IO_SET(OUT_PORT, OUT) #define DLY_1ms 65 //delay for 1ms - compiler / mode specific //end hardware configuration //global defines #define IO_SET(port, pins) port |= (pins) #define IO_CLR(port, pins) port &=~(pins) #define IO_FLP(port, pins) port ^= (pins) #define IO_GET(port, pins) ((port) & (pins)) #define IO_OUT(port, pins) IO_CLR(port, pins) #define IO_IN(port, pins) IO_SET(port, pins) //#define NOP() nop() //global variables int trg_cnt=0; //initialize the timer void tmr_init(void) { IO_IN(TRG_DDR, TRG); //TRG as input OUT_OFF(); IO_OUT(OUT_DDR, OUT); //turn off output, as output trg_cnt=0; //initialize trigger counter } //delay void delay(unsigned int dly) { while (dly--) NOP(); } //delay ms void delay_ms(unsigned int ms) { while (ms--) delay(DLY_1ms); //waste time } //reset the mcu void mcu_init(void) { //initiation code //specific to 12f675 CMCON = 0x07; //turn off analog comparator ANSEL = 0x00; //all pins gpio } void main(void) { mcu_init(); tmr_init(); while (1) { delay_ms(TRG_PR); //waste some time //IO_FLP(OUT_PORT, OUT); //flip output pin - for debugging //scan the trigger input if (TRG_ACTIVE()) trg_cnt+=1; //increment trg_count if trg is active else trg_cnt=0; //otherwise, reset trg_counter //test to see if trigger has been asserted if (trg_cnt>=TRG_DUR) { //trg remained on long-enough OUT_ON(); //turn on the output trg_cnt = TRG_ON; //reuse trg counter while (trg_cnt--) delay_ms(TRG_PR); //keep the output on for enough time, and blocking the trigger input OUT_OFF(); //turn off the ouptut trg_cnt = 0; //reset trg counter } } return; }
Basic operations: the mcu waits for the trigger pin (TRG) to be asserted (in this case, steady active high after TRG_DUR * TRG_PR, or 300ms). After that, the output pin (OUT) goes high for TRG_ON * TRG_PR, or 50ms. and the cycle starts again.
Customization:
1) if you change compiler (XC8 1.12 for me) or mode, you will need to change DLY_1ms to achieve the right timing;
2) if you change chips, you will need to change the fuse settings as well initialization section of the code;
3) if you want different pin / port combination, you will need to change the TRG and OUT macros to point to the right port / pin. The code can drive multiple output pins as is;
4) if you need different timing, change TRG_PR, TRG_DUR and TRG_ON;
5) if you need different logic, change the code.
6) the code should compile relatively easily for 10f200 as well.
7) the way it is implemented, the code is naturally anti-debouncing.
Here is a quick simulation of it.
So it may not do exactly what you want but it should get you started.
by Jeff Child
by Jake Hertz
