Thevenin theorem.. Find power
sonutulsiani
Joined Jan 27, 2010
27
Find the Power consumed by 90 Ohm Resister by using Thevenin’s Theorem
I got the power as 2.5 watts. But I got the current as -0.166 A That's why I thought it may be wrong. Can you please do and check if my answer is correct or not?
hgmjr
Joined Jan 28, 2005
9,027
As this is homework, the purpose of which is to acquaint yourself with analysis of such circuits, how about providing us with your worksheets so that we can see the method you used in getting your answer to the power across the 90 ohm resistor.
hgmjr
The Electrician
Joined Oct 9, 2007
2,986
Your first 3 equations are correct. Vth is -10 volts.
Equation 4 has a problem. You seem to be using the bottom edge of your circuit for the reference, so when you replace the 150 volt source with a short, V1 becomes zero; there is no node V1 anymore. There is no longer any need for KCL at V1, because V1 is now ground; V1 can't possibly be 165 volts. So, get rid of that equation 4.
Also, you aren't treating the 3I dependent current source correctly, even if there were a voltage at V1. (The left end of the 3I dependent current source is grounded now, anyway.)
Get rid of V1 in your next two equations and try again.
t_n_k
Joined Mar 6, 2009
5,455
Consider your second equation ...
-3I+(VA-V2)/60+VA/30=0 ****** equation (2)
You should keep in mind that VA/30=I or VA=30I
make the substitution for VA into you equation (2) above and you will
then have V2 simply as a function of I. You'll get V2=constant*I where the constant could be negative.
Substitute V2 as a function of I into your first equation ....
(V2-V1)/45 +V2/15 + (V2-VA)/60=0 ****** equation (1)
Again remember VA=30I and you know V1=150. So you'll then have an equation with the only unknown being I - for which you can then solve.
Knowing the value of 'I' will give you VA.
You can then find the Thevenin resistance to give the complete equivalent circuit.
t_n_k
Joined Mar 6, 2009
5,455
Incidentally, you shouldn't be surprised if the Thevenin resistance is negative in this case. I'm still getting my head around that one. But it all seems to work out OK - mathematically speaking.
The Electrician
Joined Oct 9, 2007
2,986
This is his equation 3 (before simplification). He has a circled 3 to indicate the simplified version.
This is his equation 2. His equation 1 is V1 = 150
He actually did ok finding VA.
This is the part he is having trouble with.
t_n_k
Joined Mar 6, 2009
5,455
Thanks Electrician - I missed that he had found VA. Good work on sonutulsiani's part!
Sometimes it's a challenge to wade through pages of handwritten work. You are more patient than I am.
Yep - finding Rth is deceptive.
sonutulsiani
Joined Jan 27, 2010
27
So now I got Vab after after solving for V2 and Va.. Va = -19 V - Vab
So then for current I got this equation:
10 - 19I + 90I = 0
I = -0.1408 A
Power = 1.785 watts ?
