thevenin and norton rlc circuits
rents89
Joined Feb 5, 2009
14
yeh sorry didnt read it, i have done some calculations, but i am unsure about the method.. was wonderin if anyone could point me in the right direction...? thanks alot
rents89
Joined Feb 5, 2009
14
ok
for q1:
- tried to find thevenin's impedance (Z_Th)
-then calculated V_Th
-finally V_Th/(Z_Th - j40) to find the current in the capacitor.
q2:
-converted voltage source to current and got 0.375<0° A
-rearranged the circuit and trying to find Z_Norton
pretty stuck basically...
cheers guys
The Electrician
Joined Oct 9, 2007
2,986
So far, so good. Now show the calculation for Vth. Show the final result.
Then show the final number you get for the current in the cap as a single complex number, but also show the steps to get that result.
rents89
Joined Feb 5, 2009
14
sorry just saw the post,
V_Th= 133.04< -141.70°
I= ((V_Th/(Z_Th - j40))= 3.31<-88.49°
=2.86+1.66i
rents89
Joined Feb 5, 2009
14
safe cheers, is the method for calculating the current in the cap correct?
also any help on q2? cos i converted the voltage source to current, is that right?
thanks alot man
The Electrician
Joined Oct 9, 2007
2,986
=2.86+1.66i
You have Vth wrong; I showed the mistake in the previous post.
Vth = 149.91<12.995°
Then I = ((Vth/(Zth-j40)) = ((149.91<12.995°/(22.486<12.995°-j40) =
3.6346<70.907° = 1.1889 + j3.4346
I think your only mistake was getting Vth wrong.
Have you attempted the second problem yet?
