hi..
i have collected the following data from ztp135sr datasheet
for 25 degree the output will be 0.156mV(approximately)
for 80 degree the output will be 10.56mV(approximately)
if i want to produce 0 to 5 v respectively for 30 degree to 60 degree what are the steps should i follow?
0 to 5 v should be given in to ADC..
this ZTP135SR consists thermister which will use for temperature compensation.i have to consider that one too..
can any one suggest me the things which i have to follow to build the signal conditioning unit for thermopile
thanks in advance....
