ElectricSpidey
- Joined Dec 2, 2017
- 2,776
No, but shorts do happen.
This is a reasonable good paper on:What happens if the light bulb is shorted?
3 watt glow plug?
So you were referring to the wires to the lamp shorting?I was NOT referring to a bulb failure.
My guess is they considered what could go wrong at design time. Low fuel indicators have been made this way for decades that I can recall. There is also no shortage of fuses on most bikes.What happens if the light bulb is shorted?
Years ago a few fuses covered a car or truck. I really have no clue how many fuses are in my truck and then to complicate things even more they are in three separate locations and maybe a few I have yet to find.Fuse...good answer.
Or a fried bike.I guess a fuse beats replacing a fried harness.
Hi, wondering how your low fuel light tests turned out ceefna.Hi and thanks for all the replies. I have scoured Google to try to find any info on motorcycle fuel tank temperatures. I would have thought that fuel stored in a non insulated metal tank above a 1000cc winging would get quite hot indeed! Looking at the 68Ω thermistor it would only need a 5° temp rise to drop below the 56Ω light trigger.
I have ordered a 68Ω / 100Ω and 150Ω thermistor to do some tests.
The 150Ω looks like it will trigger the light between 45 and 50° which may give me a better tolerance with hot fuel.
Ceefna
by Aaron Carman
by Duane Benson
by Jake Hertz
