Thermistor for simple breath detector
Sensacell
Joined Jun 19, 2012
3,789
The thermistor idea is viable, but not widely used, that's why there are so few "simple" circuits to be found on the web.
It's often true that circuits that have few components are often harder to get working, beginners can be intimidated by the number of parts in a circuit, but in reality, the complexity can yield design s that are more tolerant of part variations, therefore require less fiddling around to get them working.
I would go for something brutally simple.
For example, you could use some simple optical sensors to detect the movement of thin pieces of aluminized mylar film that could be positioned to move easily in the stream of your breath.
You can troubleshoot this system without extensive electronics knowledge, it's all rather intuitive.
Janis59
Joined Aug 21, 2017
1,894
If witchcraft around Pirani circuit of constant temperature bridge - dont forget that is inertial object demanding a kind of Pi or better PID control to not get clinched or contrary - oscillating.
