AlbertHall
- Joined Jun 4, 2014
- 12,653
I've got three 270 degree meters that someday I may make into a clock.Hello,
How about a analog meter clock:
https://spectrum.ieee.org/geek-life/hands-on/build-a-retro-timekeeper-that-never-was
Okay, that is F-ing awesome. If this is ferrofluid, I have wanted to play with ferro-fluid, but have been afraid of it getting away- it can be dangerous if not kept carefully contained. This *so* totally rocks.Hello,
An other weird clock is with a magnetic fluid:
https://www.tuvie.com/rhei-liquid-clock-creates-beautiful-illusion-where-time-always-moves/
More here: https://www.tuvie.com/search/digital+clock+designer
This design is proving to be a real challenge... my plan is to dip and join the pins at their tips, behind the board, into a single block of resin. But these blocks have to be somehow separated by walls when the resin is poured, and there's very little space between the pins to accomplish that comfortably... maybe if I 3D print said walls/containers?Here's a more detailed proposal:
This design measures 300 x 150 mm, which I considered to be acceptable dimensions for viewing from a distance of at least 5 meters, and makes use of exactly 2,000 brass plated pins
I plan to use 25 mm long, 1.4mm dia pins with 2.8 mm dia heads. Said pin is shown at the left of the image, and if I can make it stick out of the board at least half its length then I'm pretty sure I'll get the desired effect.
That, my friend, is an excellent idea... I do own a good and precise CNC mill that could do the trick. In fact, I'm going to have it drill the board's 2,000 holes. So having it drill and cut solid back supports for each segment should be a piece of cake. Making and assembling the rest of the background with the same technique is going to be far more laborious, but it's feasible nevertheless.If the pins are evenly and repeatably spaced ...
3-D print, CNC machine, or CNC drill a block with pockets for each pin, maybe 1 or 2 pin diameters in depth, and just barely larger in diameter than the pin diameter. Put a small bit of resin or adhesive in the bottom of each pocket, and press the block onto a group of pins. Now you have a free-moving, non adhesive block with the pins attached, and you control the outside dimensions of the block (so adjacent block areas do not rub together) either directly in the 3-D print or as a post-machining process. No mold forms.
That is hilarious - ! Someone with waaaaaaay too much spare time.There is also the plotclock.
Sorry, no progress so far. I'm up to my neck with work right now and haven't made the time to follow this project through ... but I will, eventually ... *sigh* , I've been working practically seven days a week these past few months and I'm feeling burned out ... I need a vacation, or something....@cmartinez any progress on this project? I was eager to see what you'd make.
That'd be the death of me. Partial color blindness.(red, blue, green, cyan, magenta, yellow and white) to convey information.
Not a job I'd want. But the clock would be more interesting if the person inside is female, wearing a bikini (from a man's perspective). Even though she'd be obscured, there would be a lot of imagination going on.Everyone here keeps approaching the problem of displaying the time from inside the box.
