The Thermal voltage V(T) of a transistor is across which points ?
silv3r.m00n
Joined Apr 15, 2010
70
So just like V:BE is across the base and emitter ...
The thermal voltage represented as V:T = kT/q
which points is this voltage across ?
38,451
The thermal voltage is not a readily measurable voltage between semiconductor terminals (its value is only about 26mV at room temperature).
It appears in the Shockley diode equation which shows the relation between a semiconductor diode junction voltage and current.
kT/q also shows up in the value for
re in a BJT as shown here.
DarthVolta
Joined Jan 27, 2015
521
Is it a sort of measure of how many electrons jump into the conduction band of a material, just from the temperature/ average kinetic energy of the material ?
IDK enough about this stuff, do metals have a thermal voltage ?
In a diode, is it the delpetion layer voltage that would be from what I wrote 1st ??
I wish I had friends IRL to talk science with.
DarthVolta
Joined Jan 27, 2015
521
In an atom, if an electron jumps up to a higher energy, a less bound shell, is there considered an actual voltage difference between inner and outer shell's, or am I mixing up shells with energy levels, and they are in Joules not J/C anyways
What's the voltage between inner and outer shells, I know in QM they are still considered as orbitals of different radii, right ? Sooner or later I'll learn about thermal voltage, I've used it tho in small signal model of BJT
38,451
Yes, the energy level changes, not the voltage.
Again, the difference is energy level, not voltage.
Temperature is the movement or vibration of the atoms in a material.
In a conductor this also involves movement of the free electrons, which shows as a random AC noise voltage proportional to the conductor resistance, or alternately as a noise current inversely proportional to the resistance (as related by Ohm's law).
