Hi, n9xv, it appears as though we now have acommon position on the NEUTRAL WIRE. But you have introduced two new pieces of CONFUSION. 1 -"a light bulb connected to an outlet is indeed a series circuit. NO SIR !! This is called a SIMPLE CIRCUIT . A series circuit would have to have at least two components( and not one) connected end to end. YOU then reduced 100 paralell bulbs to a series circuit out of the same confusion. 100 light bulbs in paralell is just that a -PARALELL CIRCUIT. 2 You agree that the NEUTRAL WIRE would have the sum of the two HOT WIRES and thus you have a SERIES CIRCUIT. This is an incorrect conclusion.In a SERIES CIRCUIT the current is the SAME.THESE CIRCUITS DO have unbalanced loads.The current thus are NOT the SAME You add current in PARALELL CIRCUITS. So if you agree the NEUTRAL WIRE carries the sum of the TWO HOT WIRES ,this has to be a PARALELL CIRCUIT. My only interest in engaging in this exchange is because of the number of persons who read these posts.Originally posted by n9xv@Jan 20 2006, 07:28 PM
The branch wiring extending out of the breaker pannel is all parallel from the source. A load connected to the individual outlets however, constitutes a series circuit. For example, A light bulb connected to an outlet is indeed a series circuit.
You can expand the idea to 100s of light bulbs "parallel" connected across the outlet. However, the 100s of light bulbs reduced to their equivalent resistance constitutes a series circuit with regard to that individual 120-volt outlet.
A 120-volt circuit has only one hot wire. A 240-volt circuit has two hot wires.
Above, you said;
"---the neutral wire would have the sum of the two HOT WIRES CURRENT FLOW."
Thats exactly right! because at that point you have a SERIES circuit and would indicate the sum total of ALL the individual return currents from ALL of the PARALLEL branches.
[post=13302]Quoted post[/post]
