Already caught that and corrected. That was a close one. I may have ruined the scope operating it with mismatched colors and violating the warranty!First things. Change that yellow slip ring on the CHAN 2 probe to purple to match the scope CHAN 2 color.
Checked. I have the lasted version. Thanks!Second thing. Set the probe attenuation to 1X and the INPUT channels to 1X.
Use the Y measure cursors and take some voltage measurements.
Now change the probe attenuation to 10X and the INPUT setting as well.
Repeat the Y measurements and see if the scope took the 10X setting into account.
If there is a discrepancy then you need to update the firmware.
(Another check would be to see what version firmware is on your scope.)
Enjoy.![]()
All of the features that you get with this thing is amazing! I like the separate controls for the 2 channels. I always disliked the single control on the Rigol. I was a bit worried about the color for channel 2. Rigol uses a purple for FFT. It is very hard to read. The colors aren't bad on the Siglent. Though I wish these companies would allow color changes for the display. Lots of color blind males out there.Enjoy your new scope. I got mine in late October and am very pleased with it.
