The MPHASE box
A fairly simple serial command response controller using the PIC18F45k80, max232 RS-232 converter and mainly leftover previous project parts for a automatic digital servo amplifier programmer.
https://github.com/nsaspook/mphase/blob/master/srhmi_e.pdf
The software is programmed in XC8 2.0 with MCC 3.66 for the boilerplate module configuration templates. Version 2.0 has C99 compatibility so you can use non-constant initializers in structures and/or designated initializers with a few other added goodies over old C90 ANSI C.
C:
// Display, command/response strings
#include "../app.h"
static const struct CR_DATA CrData[] = {
.headder = "MCHP Tech MP V",
.bootb = "Boot Button Pressed ",
.buttonp = "When done press OK ",
.done = "Resolver value SET ",
.blank = " ",
.c1 = "booting...",
.r1 = "booting...",
.c2 = "HVER\r\n",
.r2 = "Drive 70",
.c3 = "MPOLES\r\n",
.r3 = "24",
.angle = ".",
.diskmove = "Wait, moving",
.error = "Reboot SPIN AMP\r\n",
.s1 = "Press Clear Error on",
.w1 = "Spin Motor SCREEN ",
.s2 = "Press FLIP UP on ",
.w2 = "MID LEVEL SCREEN ",
.s3 = "Power Cycle Spin AMP",
.w3 = "with Scan Safety Key",
.dis = "DIS\r\n",
.msg2 = "MSG 2\r\n",
.mpoles0 = "MPOLES 0\r\n",
.mphase90 = "MPHASE 90\r\n",
.opmode2 = "OPMODE 2\r\n",
.en = "EN\r\n",
.t35 = "T 35\r\n",
.pfb = "PFB\r\n",
.msg0 = "MSG 0\r\n",
.mnumber0 = "MNUMBER 0\r\n",
/* CHANGE THIS TO THE REAL 'SAVE' COMMAND
* in the production version.
#ifdef PRODUCTION
.save_parm = "SAVE\r\n",
#else
.save_parm = "XXXXX\r\n",
#endif
.line1 = "\eO\x01\x01%s",
.line2 = "\eO\x01\x02%s",
.line3 = "\eO\x01\x03%s",
.line4 = "\eO\x01\x04%s",
.line_d = "\eO\x01\x01%s %d ",
.line_h = "\eO\x01\x04%s%s",
.headder = " ",
static const struct RS_DATA RsData[] = {
.line_m = " MPHASE %d \r\n",
.line_o = "\eO\x01\x02 offset %d",
.line_s = "%s",
.line_m = " ",
// set strings to the proper controller
const struct CR_DATA *cr_text = &CrData[MC_SS600];
const struct RS_DATA *rs_text = &RsData[MC_SS600];
// mainline code fragment using const string data.
switch (appData.state) {
//Initial state
case APP_INITIALIZE:
if (APP_Initialize()) {
appData.state = APP_CONNECT;
display_ea_init(700);
BUZZER_OFF;
display_ea_ff(1);
display_ea_cursor_off(1);
display_ea_version(1000);
StartTimer(TMR_DIS, DIS_REFRESH_MS);
} else {
appData.state = APP_INITIALIZATION_ERROR;
break;
//Initialization failed
case APP_INITIALIZATION_ERROR:
appData.error_code = ERROR_INITIALIZATION;
BUZZER_ON;
break;
case APP_CONNECT:
appData.state = APP_COMMUNICATE;
if (MC_ReceivePacket(appData.receive_packet)) { // received data from controller
clear_MC_port();
BUZZER_ON;
appData.got_packet = false;
if (strstr(appData.receive_packet, cr_text->r1)) { // power restart
appData.mc = MC_BOOT;
appData.got_packet = true;
if (strstr(appData.receive_packet, cr_text->r2)) { // hardware version
if (appData.mc == MC_BOOT) {
appData.mc = MC_DRIVE;
} else {
appData.mc = MC_INITIALIZE;
if (strstr(appData.receive_packet, cr_text->r3)) { // motor poles
if (appData.mc == MC_DRIVE) {
appData.mc = MC_SETUP;
} else {
break;
// end fragment
I must say that XC8 2.0 has lots of quirks with code memory management and will give 'psect' (can't find memory section) errors if 32-bit floats are used. The best way about this is to isolate all floating point code, variables and operations in a separate C module so the compiler can optimize it separately from mainline code.
C:
#include "pfb.h"
// resolver angle data from controller parser
uint16_t get_pfb(const char * buf)
float offset, mphase, offset_whole;
char *token, pfb_ascii[MC_RX_PKT_SZ + 2], s[2] = " ";
strcpy(pfb_ascii, buf); // make a local copy of the data
token = strtok(pfb_ascii, s); // start token search
token = strtok(NULL, s); // look for the second number
if (token != NULL) {
mphase = atof(token);
offset = ((MOTOR_POLES / MOTOR_PAIRS) * mphase) / 360.0;
offset_whole = trunc(offset); // get the whole part with no rounding
offset = (offset - offset_whole)*360.0; // extract fractional part for angle offset calc
/* need to round and convert data to integer */
return(uint16_t) roundf(offset);
} else
return(666);
Simple one-sided solder pad board with 28awg direct wiring between components.
The box eliminated the need for a laptop with serial port and terminal program for the zero procedure.
Still need to add the serial port connector to the box instead of a ribbon cable. :(
Complete software and most of the doc's used. Still needs some error checking work.
https://github.com/nsaspook/mphase/tree/xc2.05_version
C:
#include "mcc_generated_files/mcc.h"
#include "app.h"
#include "config.h"
* Main application MPHASE
* A simple command, response parser that generates the proper offset angle
* to program a direct drive servo motor system with a resolver for the
* drive angle rotation/speed feedback. Serial port 1 sends and receives data on the
* servo control port. Serial port 2 updates a 4*20 LCD display.
* Both serial ports are 9600 baud with no flow control.
* There are two control buttons for the operator interface LCD. The top button near the
* display is the 'OK' that should be pressed after the required action on the
* LCD display has been executed. The second smaller button near the bottom is
* the 'BOOT' button that allows the operator to bypass the wait for the
* servo controller auto boot sequence so the operator can program an already running
* motor control system. The 'BOOT' button can also reboot the MHPASE box by quickly pressing
* the 'BOOT' button and then the 'OK' button in sequence.
* Normally the servo controller is powered off first for a resolver calibration.
* The MPHASE box serial cable with DB9 connector is attached to the servo DB9 serial port,
* power is supplied to the MPHASE box via the attached power brick and
* then 'RUN' power is switched on to the servo controller and motor.
* The MPHASE box display should display a series of prompts with audio beeps
* if the serial connection is correct and the servo responds in the expected manner.
void main(void)
// Initialize the device
SYSTEM_Initialize();
PIN_MANAGER_IOC();
// If using interrupts in PIC18 High/Low Priority Mode you need to enable the Global High and Low Interrupts
// If using interrupts in PIC Mid-Range Compatibility Mode you need to enable the Global and Peripheral Interrupts
// Use the following macros to:
// Enable high priority global interrupts
INTERRUPT_GlobalInterruptHighEnable();
// Enable low priority global interrupts.
INTERRUPT_GlobalInterruptLowEnable();
// Disable high priority global interrupts
//INTERRUPT_GlobalInterruptHighDisable();
// Disable low priority global interrupts.
//INTERRUPT_GlobalInterruptLowDisable();
// Enable the Peripheral Interrupts
INTERRUPT_PeripheralInterruptEnable();
// Disable the Peripheral Interrupts
//INTERRUPT_PeripheralInterruptDisable();
while (true) {
APP_Tasks();
C:
// This is a guard condition so that contents of this file are not included
// more than once.
#ifndef XC_HEADER_TEMPLATE_H
#define XC_HEADER_TEMPLATE_H
#include <xc.h> // include processor files - each processor file is guarded.
* timer 0: key bounce and delays
* timer 1: software timers on low interrupt vector
* timer 3: speaker sound generation
* RA5 speaker driver pin
* RA0 LED driver pin
* usrt 1: motor controller comms
* uart 2: LCD comms
* EXT INT 0: SW 1 push detect
* EXT INT 1: SW 2 push detect
* EXT INT 2: SW 3 push detect
* EXT INT 3: SW 4 push detect
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
// TODO If C++ is being used, regular C code needs function names to have C
// linkage so the functions can be used by the c code.
#ifdef __cplusplus
#endif /* XC_HEADER_TEMPLATE_H */
This is typical motor that MPHASE will calibrate the resolver for.
Direct driver motor with encoder for slow speed indexing and resolver for high speed spin angle detection.
Vacuum chamber motor mount.
https://www.microchip.com/wwwproducts/en/PIC18F47K42
With the prototype software done the hardware is being moved to a new SIB board (pic18f47k42) designed to handle several types of diagnostic and routine maintenance control units.
