When was the last time you worked on brakes?I agree. For one thing the rivets holding the brake pad to the shoe would have done far greater damage, and likely at some point the outer ring would have broken away from the fins and would have created all kinds of havoc.
Guess I'm showing my age. Yeah, you're right - pads are not riveted on. That was "Brake Shoes". Still, it looks like that brake rotor was cut on a grinder. There's no way a person could drive a vehicle like that without catastrophic destruction of the braking system at that location. It'd yank that pad and jam up or break the braking system.When was the last time you worked on brakes?Disk brake pads have never been riveted as far ass I know. And that was a vented rotor, they have no outer ring. The part that's missing looked exactly like the part that's still there. Vented rotors are two seperate flat discs with fins in between, all one cast part.
Guess I should have become a coder. I could have handled that one. Right up my alley.Twitter source code was leaked on GitHub shortly after Musk’s layoff spree
Begin:
GOTO Begin
Disk brakes need flat surfaces on both inner and outer rings. The space in-between the rings are the louvers for venting away heat from the brake disk. The one in the picture is clearly modified with the intent to make it look like someone's an idiot who could drive a car to that much damage - and live to tell about it.that was a vented rotor, they have no outer ring.
no, that is another type of brake disc, one made to bolt to a separate hub. Many high performance , race type disc brake rotors are mad like that, so the high temperatures from braking don't burn out the wheel bearings.The one in the picture is clearly modified with the intent to make it look like someone's an idiot who could drive a car to that much damage - and live to tell about it.
Your assumption is correct, but it only is that way when a disc brake system is properly maintained. The caliper is contained from rotating when the brakes get applied by a bracket on the spindle and there are two "pins" that connect the caliper to the bracket. If when a brake job is done the pins are not lubricated usually only one side of the caliper is actually doing any thing to stop the disc. And it isn't allowed to let the caliper recenter its self after the brake is released. In my years of doing car work it is the out side pad that wears out before the inside. The inside is where the hydraulic piston is located so when the brake pressure is released and the piston retracts, that pad is more free to move. But the outer one is stuck in place against the rotor due to the friction on un-lubricated pins. So then the outer pad is always rubbing the disc.My assumption has always been that disk brakes and their calipers depend on two pads compressing (gripping) the rotor and slowing or stopping the car.
photos showing programmers before and after Musk tells it al. also check the video clip below it ("day at work at twitter")Guess I should have become a coder. I could have handled that one. Right up my alley.
My daughter got an 87 on a math test.
The Exercise Thread | Off-Topic | 22 | |
Someone changed my thread title w/o my permission!! | Feedback and Suggestions | 12 | |
Thread deletions | Off-Topic | 1 | |
Another battery thread | Power Electronics | 8 | |
The Frauds Thread | Off-Topic | 14 |
