the differentiation of a wave
Ghina Bayyat
Joined Mar 11, 2018
151
i need a help
i know that the differentiation of a square wave creates a spike wave 20190901_104741.jpg
but what if the input wave is the spike wave ? how would its differentiation look like ?
can u please help
35,145
You can analyze a differentiator from the perspective of frequency domain.
A differentiator is also a high pass filter. It attenuates low frequencies while it passes high frequencies.
Two differentiators cascaded alters the frequency response of the high pass filter.
In order to turn the square wave into a sine wave, you need a narrow band pass filter or a tuned resonator.
OBW0549
Joined Mar 2, 2015
3,565
You can double integrate a square wave to get a sinewave.
I don't believe that's correct; it's equivalent to saying that you can double differentiate a sine wave to get a square wave, which is obviously untrue since no matter how many times you differentiate a sine wave you simply end up with another sinusoid.
Double integrating a square wave will certainly reduce the amplitude of the fundamental's harmonics drastically and yield a much "rounded" waveform; but it will not be a sine wave since the harmonics are not reduced to zero.
MrAl
Joined Jun 17, 2014
13,790
i need a help
i know that the differentiation of a square wave creates a spike wave View attachment 185144
can u please help
Look up "unit doublet"
If you differentiate a pulse you get two impulses one positive and one negative. If you let the pulse width tend to zero you get a doublet. Conceptually it's like a positive impulse with an immediate negative impulse.
With concepts like this is it more important to understand the effects it has on other things like circuits especially filter circuits than what it really means all by itself.
MrAl
Joined Jun 17, 2014
13,790
Yeah i agree we should not say that double integration of a square wave produces a sine wave unless we add a qualifier such as that the sine wave is not a perfect sine wave.
It's really two exponentials and can easily be shown to just *approximate* a sine wave.
OBW0549
Joined Mar 2, 2015
3,565
I believe that double integration of a square wave yields a sequence of parabolas of alternating polarity, not a sequence of exponentials. Integrating a constant yields a ramp, and integrating a ramp yields a parabola.
MrAl
Joined Jun 17, 2014
13,790
Yes i called it exponential but meant its a second degree expression. Ive plotted the two on top of each other and the difference is clear. ill plot again.
38,780
True, I should have stated that. :oops:
The Ltspice simulation below gives a total harmonic distortion of 3.7% for the double-integrated square-wave, which may be good enough for some applications.
MrAl
Joined Jun 17, 2014
13,790
View attachment 185165 View attachment 185166
Yeah for most i would bet except fine audio tests.
Back in the 1980's i used a nonlinear sine generator which used nonlinear wave shaping starting with a triangle and i would have loved to have a wave as good as 4 percent THD (ha ha).
AnalogKid
Joined Aug 1, 2013
12,266
A "spike wave" has a very fast leading edge just like a square wave, and that is what "gets through" a differentiator. The output will be another spike, and its shape will depend on the relationship between the width of the input spike and the time constant of the differentiator. The longer the time constant, the more the output spike will be exactly like the input spike. As the time constant gets shorter, the output spike gets narrower than the input, and with lower peak amplitude.
ak
MrAl
Joined Jun 17, 2014
13,790
Here is my simulation using a behavioral source to generate the polynomial of interest...
The calculated THD using 1001 harmonics came out to 3.80405 percent and agrees with LTSpice with 1001 harmonics.
The calculated harmonics are found from the Bn which simplifies into:
B[n]=(8*pi*n*sin(pi*n)+16*cos(pi*n)-16)/(pi^3*n^3)
and that is divided by the first harmonic B[1], squared, then summed from 2 to N
then the square root is taken to get the fractional THD, then multiply by 100 to get the THD in percent.
Here is the 21 digit THD in percent with 100001 harmonics:
3.80404605774183799705
and that should be accurate to that many digits.
Just to note, with 41 harmonics the THD in percent rounds to 3.80405 as in LTSpice.
Ghina Bayyat
Joined Mar 11, 2018
151
thanks for ur help everyone but i'm actually stuk with this circuit
20190902_145239.jpg 20190902_145257.jpg what i can't understand is how did waveform E turn into waveform F ? how could a spike wave like E turn into a sine wave like F ?
bobpease4ever
Joined Jul 28, 2019
23
i need a help
can u please help
The spike has infinite slope. So if you differentiate IT the result is also a spike of infinite slope. There's little difference in those kinds of infinities. But in practice it's not really a spike
