As many of you are aware, I am a serious bird photographer. Random examples:
A couple of weeks ago, tragedy struck. A terrible gravity accident occurred causing my Canon EF 500mm /4L IS USM lens and the attached Canon EOS 7D Mark II camera body to plummet at 9.8m/s² from a height of about 1.5m. The results were horrific.
The lens literally broke into three pieces, shearing screw heads off and breaking magnesium castings that spanned the sections. The flex PCB interconnects were severed and the wires were torn from the camera interface pins. The lens mount and a piece of the lens were left attached to the camera which at first seemed to be OK but upon further inspection had some mysterious problem preventing lenses from being properly mounted and recognized.
You can imagine I was not very happy with this outcome. There is some insurance coverage but just how much is still up in the air. In the end I will certainly be out of pocket on the order of a couple thousand bucks. And, I couldn't take bird photos. I tried an alternative setup with ,y Canon 5D Mark IV, EF 70-200mm /2.8L IS USM, and a 2x Extender III—but that only got me 400mm at the top while i had been using 1100mm! The difference was just too much. I got a few photos but it was very different.
So a little diversion into the math of this is in order. This might be the part where you stop reading (if you've gotten this far) but this is actually interesting in a photonerd way, and if you haven't looked into this stuff it might be interesting to learn.
For birds, you really want as "long" a lens as you can manage. There are tradeoffs involved that affect image quality, light gathering, and portability among other things io it's an optimization problem, not some fixed thing. First what is a "long" lens?
It might be physically long, and they tend to be, but clever design can make an optically longer lens sorter than an optically shorter one. No, ";one" in this case refers to focal length. If you get really technical what we call focal length in photography is actually effective focal length. This is because there is a front and rear focal length and for practical purposes we don't really care about that.
The focal length of a camera lens as it is conventionally notated is the number of millimeters from the rear nodal point to the focal plane when the focus is set to infinity. By convention this focal place is relative the size of a 35mm film negative. This leads to a lot of misleading impressions concerning lenses for other sensor sizes but that's a different subject.
"Long" lenses are telephoto, FoV (Field of View) being inversely proportional to EFL (Effective Focal Length). This means a long lens focuses things far away and with a very narrow field of view. Shorter lenses, approaching wide angle d the opposite focusing close with a wide FoV. (There are details I am glossing over because this is already going to be unreasonably long.)
In the system we are talking about, the total EFL is influenced by three things: the lens, an possible extender (explained below), and the sensor size. The lens is easy, a 500mm lens is 500mm when used with a FF (Full Frame) sensor—one that is the size of 35mm film. So we start the calculation there with 500mm EFL.
The there is the option of using an extender which is an specialized lens that has a lens mount on one end and a body mount on the other—that is, it has the same mount as the camera body to which a lens can attach. The extender increases the focal length of the lens attached to it. In the case of Canon there are two options: 1.4x and 2x. Nothing is free, though. The cost of these extenders is loss of light.
The 1.4x extender costs one stop of light and the 2x costs 2. A stop refers to an stop which is the opening of the iris of the lens relative to the light it passes. From one stop to the next is half the light when reducing. The actual details of this are out of scope but you can read about it, it's interesting. The stop numbers are not linear. If I have an /4 lens one stop down is /5.6, the next is /8 and so forth.
So the 1.4x extender turns the /4 lens into an /5.6 lens. This means considerably reduced light gathering requiring choosing lower shutter speeds or higher ISO (sensor sensitivity) or some combination. Slower shutter speeds mean more blur from motion, which can mean less sharp images even in a "still" subject. Higher ISO means more noise which can reduce image quality.
In general I shot with a 1.4x extender in place, bringing my EFL up to 700mm.
There are smaller and larger sensors and that affects the overall EFL.
Larger sensors, like medium format (MF) need longer lenses just to get "normal" results. They will turn what would be a telephoto lens for a FF camera into a wide angle. They also need a much larger circle of light since the sensor is larger. Smaller sensors like APS-C which is about 62.5% of a FF (in Canon's case, and about 66% in the case of most others).
The effect of the smaller sensor is that it sits in the center of the circle of light from the lens. This means it only sees what is in the middle. If you think about it, this is like the MF case but inverted. This means that what would be a fairly wide lens on a FF is a telephoto on the APS-C (also called "crop sensor" which is a reference to anything smaller than FF) and what is a telephoto for FF is a supertelephoto on the crop sensor camera.
Just how much more telelphoto is calculated with what is called crop factor. This is a multiplier that is based on the relative size of the sensor. The Canon APS-C has a crop factor of 1.6 so our 700mm lens above becomes 1100mm when mounted to a crop sensor camera, which the 7D Mark II, my previous camera, is.
So the previous setup had an EFL of whopping 1100mm with good IQ (Image Quality). It's hard to imagine giving up that long, long reach once you've had it. So complications set in...
Because I had to replace the camera body I decided it was time to upgrade. The Canon EOS 7D Mark II is a great camera. Affordable, pro build quality, pro controls and menu options and with a fast. 10FPS (Frames Per Second) shutter, and exceptionally good autofocus. The last two are like a long lens, bird photographer toosl. Particularly for birds in flight fast shutter and fact AF get you shots you'd otherwise miss.
The 7D Mark II straddles the line between professional and enthusiast cameras. It is used by pros as well for sports and wildlife photography because of the above and because of its APS-C sensor providing 1.6x focal length for whatever you attach to it. I bought it for that but also price. I wasn't sure I was going to continue pursue birds in particular and wildlife in general at about 25% of the cost of other appropriate choices, it's a real deal.
But, it is being replaced with the EOS 1DX Mark II pictured above. This is the just-previous Canon flagship camera. You see it everywhere there are professional photographers: sporting events, press conferences, etc. It is a true pro camera and costs like it too. But you get a lot for that. You also get a FF sensor which is a double edged sword. The resolution of the 7D Mark II and the 1DX Mark II sensors is the same: 20.2MP.
The difference is that in the case of the 7D Mark II those pixels are constrained to a space 62.5% the size of the 1DX Mark II sensor. This that with the crop factor increasing the relative size of distant objects on the sensor, the effective resolution of cropped images is higher—and you always crop bird photos when the small birds are far away.
But the trade off is the 1DX Mark II sensor has much larger photosites (the sensor pixel) which means better light gathering and so better low light perfomance, a lot better. This can be very helpful when forced to shoot at high ISOs where th e7D Mark II will be far noisier, possibly unusably so.
Still, I lose the 1.6x bonus, and that's a big deal. I am willing to work around that, though, because the 1SX Mark II is a beast. Not 10FPS but 12FPS which is more than it sounds like, and it's designed to shoot a lot of frames without slowing down to buffer, something I have fought with using the 7D Mark II to shoot birds in flight.
It is also designed to take abuse and inclement weather and never stop. It's fully weather sealed, all titanium, and built like a brick house. When you are shooting outdoors, it sometimes rains or snows, or there are pyroclastic flows from nearby volcanoes, etc. All in all, I am not unhappy to be moving up to what, when new, was a $6000.00 camera. It will be a joy to use.
Then there's the lens. It looks like the previous one, as you can see. But it's not the same. The dear departed lens was an EF 500mm /4L IS USM. This is almost but not quite like the new 600mm /4L IS USM. That 100mm is a big deal because of moving to FF from crop. I need that so I can get 840mm rather than the 700mm of the previous lens. But as usual it comes with a cost.
That 100mm weighs 3.3 pounds. The 600mm /4L weighs 11.8 pounds, 3.3 pounds more than the 500mm /4L. It is also longer and wider.
I don't take this increase lightly (no pun in... well OK maybe a little one.). I carry my gear for several miles at a time and it's already not easy. I am just asking for trouble. But, this lens is fantastic. Sharp, fast focus, and built like a tank, the perfect match for the 1DX Mark II.
So, if you actually read this far I hope you found it informative, or at least interesting, or got some benefit from it. I will be posting new bird pictures using the duo as soon as I can. I may get them as early as tomorrow/ Stay tuned for more bird goodness.
