Test SMD Capacitor. Beginner Question
Chris Mac
Joined Sep 23, 2019
9
Hi. First post here. Total electronics beginner looking to learn how to repair all things electronics.
I heard that to test for a bad SMD capacitor, you should check for continuity to ground on both sides. It should only be grounded on one side, and if it's showing as grounded on both sides, there's a short somewhere on that line. Is that right?
So I have two identical tablets here. One with no power and one known-good. While testing the faulty one, I noticed a few capacitors on the main power rail (next to the battery connector) were beeping on both sides (black probe ground, red probe on each side one after the other)
Thing is, I took the known-good tablet to compare it with, and I'm getting continuity to ground on both sides of the same capacitors with that one too, but it works just fine. Am I completely missing something here or is the continuity test bs?
bwilliams60
Joined Nov 18, 2012
1,450
Whe you are doing continuity test, I assume you are on lowest resistance scale with audible tone on. When it beeps, is there any reading on the display or is it absolutely 0.00 ohms? I have seen where you get a beep but still show a resistance value as well.
KeithWalker
Joined Jul 10, 2017
3,628
You have been badly informed. Capacitors are not necessarily connected with one side to ground. It just depends on where they are used in the circuit. For example, in the circuit below, one side of C4 is is connected to ground but C1, C2 and C2 are not :
Chris Mac
Joined Sep 23, 2019
9
Just tested one and I'm getting anywhere between 0.3 - 0.8 ohms. It seems to fluctuate until it eventually stops between those values. Doesn't seem to be an option to change the resistance range with this MM
Chris Mac
Joined Sep 23, 2019
9
Ok thanks. That makes sense. So there's no way to reliably test without schematics?
narkeleptk
Joined Mar 11, 2019
599
Total electronics beginner.
Just to be clear, you are removing all power sources before testing continuity/resistance correct?
dendad
Joined Feb 20, 2016
4,642
It is pretty difficult to test caps in circuit, without knowing what the circuit is.
For instance, a cap can be connected across a coil as a tuned circuit. Doing a continuity test on that cap will read a short circuit. But the cap is ok.
For a real test, the cap will have to be removed from the PCB and measured.
But if you can get a circuit, testing for shorted caps can help, when you have a bit of a clue what can be expected by reading the circuit.
Chris Mac
Joined Sep 23, 2019
9
Would anyone happen to know where to start with a tablet that has no display?
I've used a known-good LCD (tested and working on the known good but not on this dead one) Known good battery. Still no luck.
Current draw is 0.45A precisely regardless of whether or not the power button is pressed or held. (10.1 inch tablet so should be 1-2A and the other identical working tablet draws around 1.5A)
LCD and battery connector on motherboard don't appear to be damaged. Also used the good cables from the good LCD to connect it. I've tested the mosfet nearest the battery connector. 3.8V at battery terminal, also 3.8V at both input and output pins of mosfet nearest the battery terminal. Which also rules out the main power fuse being blown(?) And that's where I'm stumped.
Chris Mac
Joined Sep 23, 2019
9
Got you. So without understanding the circuit, you're just clutching at straws. You'd need to have schematics and understand what's going on with them?
dendad
Joined Feb 20, 2016
4,642
First off, see if you can measure the various power supplies.
Take a picture of the board and note the readings of the good tablet and compare them to the dead one.
Chris Mac
Joined Sep 23, 2019
9
Ok, understood. How would I identify the power supplies? I've heard people talking about different power supplies on a motherboard before but to me, they all just look like the same chips and inductors as any other
dendad
Joined Feb 20, 2016
4,642
You may be lucky to find some marked on the board.
Another trick is to measure the volts across any electrolytic caps. They are often power supply filters.
narkeleptk
Joined Mar 11, 2019
599
You don't need a schematic but you need to know enough to be able look at what your working on and have an idea of what it does. It helps to work on sections at a time and even draw them out yourself if needed.
Ok, understood. How would I identify the power supplies? I've heard people talking about different power supplies on a motherboard before but to me, they all just look like the same chips and indicators ad any other
Start where your battery or power plugs in. Pick a part and google its marking with "datasheet" behind it. Study some datasheets and sample circuits of voltage regulators. After awhile you will start to recognize them easy enough. ANYTHING you don't know what it is, just search google and always add "datasheet" to your term. It helps a lot to narrow down the results even if you don't get exact matches.
Chris Mac
Joined Sep 23, 2019
9
Thanks again for the help.
Thanks, I appreciate the help. Learned a lot. I'll stick to this forum rather than asking on Reddit!
narkeleptk
Joined Mar 11, 2019
599
Hah, yeah I saw your post on reddit, I rarely go there but its seems just as bad for getting actual help as /diy/
I hang around a lot of forums and lurk around even more places but AAC is by far one of my favorites. Everyone is pretty nice and extremely helpful here. Even the grumpy members are great.
Chris Mac
Joined Sep 23, 2019
9
Ha oh you saw the Reddit post too? Guess it's a small community. Thanks so much for the advice re: datasheets. I'll have a look tomorrow
