Test jig for PSU board?
spinnaker
Joined Oct 29, 2009
7,830
I am looking at refurbing my 30+ year old Atari 800 which is working. First on the list is to replace all of the old electrolytic caps an tantalums. I did not like the idea of tearing apart a working psu so I bought a spare working board, which I imagine also has 30+ year old caps.
I wanted to make a test jig with loads. Any idea on what I should use as loads?
Reloadron
Joined Jan 15, 2015
7,888
PSU Test Demo1.gif Years ago, many years ago I was involved with a PC Hardware testing sight. They wanted a reliable test box and a way to record the data (Voltage and Current) at different loads applied. I used Ohmite "Stack Ohm) ceramic resistors and just manually switched in more parallel loads using simple toggle switches. Later design I went with using D Flip Flops to switch MOSFETS to change loads. I included some high power rehostats to trim my current. I measured the voltage and current using old 10 Amp and 50 Amp current shunts and a few Action Packs to amplify my shunt outputs.
Problem here is I don't know what your PSU max currents would be. You could maybe start by placing some higher value resistors across a known voltage out and slowly increase the load (reduce resistance) and place added resistance in parallel to increase the load until the voltage begins to fold over and drop. I used 120 VAC fans to cool my load banks.
This is an old idea of just looking at two rails:
Ron
dl324
Joined Mar 30, 2015
18,326
OK so what current should I expect an old 6502 based computer to consume. That is what I am trying to get at here.
Look at the voltage regulators. The package and/or part numbers will tell you the maximum current they can provide. Then look for information regarding the transformer windings they're using. If they're using half amp windings on a 7805, then the max current would be closer to what the transformer can source.
dendad
Joined Feb 20, 2016
4,637
Lamps make pretty good test loads for power supplies. When they are cold, their resistance is pretty low, and as they heat up, the resistance increases. So if you can get lamps rated to the voltage and current, you could try them. For example a 12V 24W lamp will be a good load for a 12V 2A supply.
Lamps give the power supplies a bit of a fright for a start so they get a stress test to see how they behave under heavy load.
spinnaker
Joined Oct 29, 2009
7,830
I was just thinking about this last night. Should be pretty straight forward.
