temperature effect - related to motors
elanium
Joined Aug 3, 2021
12
Hi . i want to study the effect of temperature on size of some small motor objects. for example a bearing with external radius 3.075 mm and internal radius 2 mm and thickness is 1.6 mm . I can calculate the volume difference but i don't know how to understand the radius changes of bearing .
slackguy
Joined Feb 11, 2016
76
bearings are not "simple things" to design. you'll need a whole thermodynamics and physics library to do it, is all. or some books on the topic of "selecting the right bearing" which en large are by experience in the field less by calculation.
mass of metal (larger size) absorbs and dissipates heat better - but take far longer to cool if over-heated
more bearings bear more load but also cause more drag
your not mentioning the type of metal, the type of lubricant if any. i mean your question is just totally off the wall
