I have one temperature controller (https://www.selec.com/product-details/universal-pid-with-white-green-display). I want to control the temperature of a stainless steel block using a cartridge heater with 50-ohm resistance and a tolerance of 50V.
I am new to instrumentation. I can't figure out how to connect this temperature controller's output to the heater. I feel I have to use an external power supply for this. However, I don't know how to decide which power supply I should purchase.
Secondly, I would like to use the analog output to control the heater. I think that will provide me with better stability. However, I am open to using the SSR output to control the heater.
Mod: added datasheet.
You can find the details of the temperature controller in the attached links.
Thank you in advance.
