retchedGet 50,000 friends with stopwatches and telephones.
If there were 50,000 operators, there would be no holding time. Is this ALL info avail on the problem?
I disagree. Average call duration cannot be determined, since the 2000 calls that were >20 minutes could have averaged more than 8 hours each.Average call duration is <20 min, but call rate is not listed, so I haven't an idea how to solve this. Im sure Erlang would have an idea. Hopefully someone else will have a formula to solve for h with so few stats.
I would think it would be 50000/48000 * 20 But I could be wrong. h=20.833
You think poisson probability distribution plays any role in this question?I disagree. Average call duration cannot be determined, since the 2000 calls that were >20 minutes could have averaged more than 8 hours each.
On the other hand, one can cay the median call time is 20 minutes or less.
John
BTW, When we studied our call center, duration of holding was not normally distributed. It seemed to be at least bi-modal. A lot of people gave up quickly (e.g., <2 minutes), but most of those who stayed seemed to be there for the duration.
| J | Theory Question About Pull Down Resistors | Microcontrollers | 10 | |
Hydraulic Engineering question: Which plan is better? | Off-Topic | 38 | |
| Y | digital signal distortion in differential lines question | Wireless & RF Design | 0 | |
| D | Teletraffic Questions | Homework Help | 2 | |
| D | Teletraffic Questions | Homework Help | 1 |
