telephone line relay
DickCappels
Joined Aug 21, 2008
10,661
Yes, if you have a 6V power supply with which to drive it, if you only +5V then answer would be "probably". Make sure the contacts are rated for over 150 VAC so then can withstand the ringing voltage.
absf
Joined Dec 29, 2010
1,968
Make sure that the 6V supply only goes to the relays and not the CM8870 DTMF decoder & PIC mcu. The decoder supply only works from 4.75V to 5.25V. The absolute max Vcc is 6V. Check the datasheet of the max supply voltage for the PIC too.
Allen
abc77
Joined May 10, 2017
59
i don't actually need the decoder. I just want to switch the line using call accept/end function.
there is BC547 transistor feeding the relay via 1kOhm, do you think lowering this resistor value will increase voltage for the 6V relay?
abc77
Joined May 10, 2017
59
I have SC5-S-DC6V relay. It says 7A, 240VAC,50Hz and coil:6VDC. Then again after a long separating line, there is 10A/125VAC. Will this do?
DickCappels
Joined Aug 21, 2008
10,661
The BC547 should have much less than a volt from collector to emitter when the relay is on if it is working correctly, so in that case lowering the 1k resistor would have very little effect. The best thing to do is to measure the collector-to-emitter voltage.
If the collector voltage is over 0.6 volts with 5 ma of base drive (close to what you get with 1k and a 5V power supply) then either the transistor is bad or the relay is pulling too much current. The maximum collector current of a BC547 is only 100 ma.
If you know or can find out, what is the coil resistance?
Do you know the pull-in voltage?
DickCappels
Joined Aug 21, 2008
10,661
Yes. It means that you are good to go with that relay and that voltage. If this were a high volume production design we would require more margin but since this is a one-off and you have a very high chance of success with this relay, go for it!
