TDR & CTMU
TAIEB
Joined Mar 30, 2021
  • I am in the process of using a pic18f46k22 to design a time domain reflectometer in Proteus, using MicroC . I'm testing it bit by bit. The PIC generates a pulse, pulse goes through a transistor to create a fast falling edge, edge goes to transmission line, the reflection is fed to a comparator which produces a pulse whose length is equal to the distance between the start of the transmission line and the reflection. I have to find the length of this pulse. The heart of the low-cost TDR system is a peripheral called the Charge Time Measurement Unit (CTMU). A CTMU peripheral on a microcontroller (MCU) can be used to measure time with a high degree of precision and resolution For this I want to use the CTMU. The rising edge of the pulse is EDGE1 and the falling edge is EDGE2. I'm using the TDR as Soil moisture sensor ? I'm searching about CTMU setting
BobTPH
Joined Jun 5, 2013
11,659
Does the CTMU have more resolution than the timer with input capture? If not, the latter is the normal way of measuring a pulse width.
Bob
