TDA 2003 amplifier
jjkk
Joined Jan 16, 2009
12
Hi all,
I am using the test circuit that is provided by the TDA 2003 data sheet to make an audio amplifier. but the output i am getting looks like a half wave rectifier output. i cann't understand why. any help much appreciated.
bertus
Joined Apr 5, 2008
23,026
Can you post a schematic?
It looks like a dc offset somewhere.
What is your powersupply?
Greetings,
jjkk
Joined Jan 16, 2009
12
i didn't bias the amplifier. i read it has its own internal biasing.
i have (+) of C2 to pin 2 and (-) to R1 and R2 junction.
bertus
Joined Apr 5, 2008
23,026
So C2 is correct mounted.
What is the voltage you are using ?
It should be between 8 and 18 Volts.
Greetings,
jjkk
Joined Jan 16, 2009
12
i found what was going on with that. i was not using proper attenuation.now the circuit is working properly so far. thanks for all your help.
Audioguru
Joined Dec 20, 2007
11,248
Did you bias the amplifier to output a voltage of half the supply voltage when no signal is present?
The test circuit in the datasheet does not show external basing resistors because they are built-in as shown on the schematic of the IC.
