TC4056A IS EQUIVALENT - NOT A CLONE
longpole001
Joined Sep 16, 2014
62
There are many clones out there of the TP4056 , some with Logo's others none
and with clones its not known if they will work or not or for how long
The problem is that the original chip of the TP4056 is often not on majority of PCB modules and more often even when its pictured you get clones sent anyway
The TC4056A is an equivalent and from what i can see so far is not cloned and has its own datasheet specific for the chip ,
The chip is appearing on a lot of tp4056 modulus and from what i can see is better option when you want to purchase , if the vendor will show you what they will send you when you buy tp4056 modules
cheers
