Tales from the grill...
joeyd999
Joined Jun 6, 2011
6,456
First problem: way too much air in charcoal compartment, even with all the vents closed. Impossible to modulate the coal temperature.
cmartinez
Joined Jan 17, 2007
8,859
Is that ceramic? Looks like epoxy powder coat to me. But wadda I know?
I'm sure it has to be ceramic, to withstand the temps and to be fda approved.... of course, I've been sure and mistaken at the same time before, but what I'm saying makes sense.
Those inexpensive grills tend to be far from hermetic. I suggest you take a closer look at it, and try sealing cavities and cracks using aluminum foil.
joeyd999
Joined Jun 6, 2011
6,456
I've never had a charcoal grill with a chimney. If I close the chimney, is the temperature supposed to go up or down? I suspect down, but it seems to have no effect.
cmartinez
Joined Jan 17, 2007
8,859
It will go down, after a while. It's important that the grill is well sealed to prevent drafts from entering other than the intended troughs.
joeyd999
Joined Jun 6, 2011
6,456
@cmartinez:
I love corn on the cob on the grill. Normally, I remove the husk, butter it, then wrap in aluminum foil and grill. Tasty!
I know COTC can be grilled in the husk. Do you know how to do this?
cmartinez
Joined Jan 17, 2007
8,859
@cmartinez:
If you're asking if cotc can be grilled directly on the coals (if that what you meant with the word "husk") then yes, it can be done.
All you have to do is throw it on the coals in its natural state, leaves and all. The outer leaves will burn, but the inner ones will not only protect it, but seal the moisture tightly. The result is an extremely delicious and tender meal...
Three things:
  • Throw the whole thing on the coals. Make sure that the tip has not been chopped off. I hate it when vendors do that.
  • To tell when it's finally done, twist it with your hands. It's done when it feels rubbery. Take it out and let it rest for a few minutes before peeling.
  • It takes a long time for this method to cook the cotc, but it's worth it.
cmartinez
Joined Jan 17, 2007
8,859
Husk: the "leaves" you mentioned.
What temperature? Approximately how long (need to know for planning meal)?
I suppose I'll know its done if it's hot enough to sear the skin from my hands... :)
Temperature: red hot, live coals
Time: from 45 min to 1:15 hrs
... and use mittens, little grasshopper... :rolleyes:
wayneh
Joined Sep 9, 2010
18,164
Totally off topic but I just saw Aseep At The Wheel at an old opera house. I’ve followed the band for years and love their music. I haven’t seen them live for a long time, so it was a real treat.
