Tactile buttons
Discussion in 'General Electronics Chat' started by Ewans, Aug 25, 2017.
  1. Ewans
    Aug 25, 2017
    5
    Hi hoping for some help. I have a pair of the wife's straighteners. There are 3 smd tact buttons, 1 for power (which works) and another 2 to increase or decrease temperature. These 2 don't work. I tried continuity while depressing and they seem ok. Is there another test I should try on them? Everything else on the pcb appears to be fine.
    Thank you
  2. Dodgydave
    Jun 22, 2012
    7,752
    1,293
    Check the heater for open circuit, also there will be a Thermistor and probably a microcontroller.
  3. Ewans
    Aug 25, 2017
    5
    Thanks for the reply. I tested the thermistor off the board and reads around 200ohm. Heaters are 164ohm each.
  4. Dodgydave
    Jun 22, 2012
    7,752
    1,293
    Do the up/dn buttons make continuity to the microcontroller pins?
  5. Ewans
    Aug 25, 2017
    5
    Hi
    Hi yes there is continuity to the pins.
  6. Dodgydave
    Jun 22, 2012
    7,752
    1,293
    So if its powering on, and not heating up, as you have checked the heater,,it must be the microcontroller or triac....
  7. Ewans
    Aug 25, 2017
    5
    Yes I think it's the pic. Initial switch on heats up to a preset 150 deg but pressing the + or - buttons nothing happens they just stay at 150. Thanks for your input. Replacing the pic probably isn't an option as I don't think they are commercially available.
  8. Dodgydave
    Jun 22, 2012
    7,752
    1,293
  9. Ewans
    Aug 25, 2017
    5
    Dodgydave likes this.
