Switching frequency of synchronous motor
electronicsLearner77
Joined May 26, 2012
127
I am doing 6 step commutation of 3 phase Synchronous motor. The pwm frequency is around 10khz. I read the formula from the documents for synchronous speed as 120 * f / p. What is the "f" here is it 10khz ? Please advise.
38,568
"f" is the PWM modulation frequency, not the PWM switching frequency.
f would be 50-60Hz for standard motor operation.
Are you trying to control the synchronous motor speed with the PWM signal?
Joined May 26, 2012
127
Not sure but in documents i read that the switching frequency should be high to avoid audible noise. How to program the pwm modulation frequency ? I mean to say i want higher speeds how to increase modulation frequency ?
MaxHeadRoom
Joined Jul 18, 2013
30,699
Picmicro recommend PWM motor control starting at around 5khz to 6khz to avoid audible buzz or noise, for a very small motor that might be an insignificant factor.
Max.
danadak
Joined Mar 10, 2018
4,057
What do you mean by "120" mode ? Just the fact you are
switching in each phase of a 3 phase system ?
The ref I gave you not exact solution to your problem, more
generalized considerations for 3 phase motor control.
Regards, Dana.
