Suppressing sparks when attaching buck converter to battery
Kermit2
Joined Feb 5, 2010
4,159
It is the capacitors charging when first connected that creates the large inrush of current which makes the sparks you see.
If you connect one terminal only and temporarily connect a 3 or 5 ohm resistor between the other terminals, the caps will charge slower and you will not have such a big spark when you remove it and connect directly.
Not any easy way.
Kermit2
Joined Feb 5, 2010
4,159
Three 9 volt batteries makes 27 volts.
Perfect for your 24 volt system.
Put three in series and attach wires so you have a 27 volt pack.
The high internal resistance of the rectangular batteries will prevent destructive sparking while the caps charge.
Leave it connected for 5 to 10 seconds then hook up the real battery pack.
