supercap charging-discharging time
ilginsarican
Joined Jul 13, 2017
147
I have 10 pcs 200F supercap in series.
I want to calculate charging and discharcing time but these formulas does not work:
Charge time formula: τ=RC for charge time=5τ
I limited the charge current to 1.2A, so I assumed R=27(supply voltage)/1.2=22,5Ohm.
But it takes 10 minutes to charge to 27V.
I want to know that whether I'm calculating something wrong.
BobTPH
Joined Jun 5, 2013
11,656
Does your series connection include balancing circuitry? If not, that is a problem.
If chaging at a constant current, the formula is:
dV/dt = I / C
Which means if you divide the current by the capacitance, it tells you how many volts it will rise per second.
Bob
ilginsarican
Joined Jul 13, 2017
147
dV/dt = I / C
Bob
there is balancing circuitry for each capacitor and also current limiter circuit top of capacitors.
BobTPH
Joined Jun 5, 2013
11,656
That is because you are charging at a constant current. That is not the same as charging through a fixed resistor. Use the correct formula that I posted.
dV / dt = I / C = 1.2 / 20 = 0.06 V per second.
So for 27V, it takes 27 / 0.06 = 450 seconds = 7.5 min.
It probably takes a little longer because your power supply can no longer provide 1.2A as the voltage approaches 27.
Bob
ilginsarican
Joined Jul 13, 2017
147
Can
Bob
Can I use same formula for discharcig?
Load consumes 450mA constantly.
