I'm pretty sure that interpreting the spherical vector coefficients as a magnitude and two angles is not consistent with the adopted convention.
Suppose you had a vector (the one I'm working on at the moment)
\(\bf A=0.535 \hat{\bf x}-2.54 \hat{\bf z}\)
How would one express the equivalent vector in spherical polar coordinates at a point P(1,3,5)?
One approach would be to form a conversion matrix
\( \left[ \bf M \right ] =\left [ \begin{array}{cc} sin(\theta)cos(\phi) & sin(\theta)sin(\phi) & cos(\phi) \\ cos(\theta)cos(\phi) & cos(\theta)sin(\phi) & -sin(\theta) \\ -sin(\phi) & cos(\phi) & 0 \end{array}\right ] \)
Where
\(\theta \ and \ \phi\)
are part the spherical coordinates of P.
P(1,3,5)=>P(5.92,32.3°,71.6°)
One would substitute
\(\theta=32.3^o=0.564 rad\) and \( \phi=71.6^o=1.25 rad\)
to evaluate the terms for matrix M
To obtain
\( \left[ \bf M \right ] =\left [ \begin{array}{cc} 0.169 & 0.507 & 0.845 \\ 0.267 & 0.802 & -0.535 \\ -0.949 & 0.316 & 0 \end{array}\right ] \)
The spherical polar form coefficients of A at P would then be
\(\bf M \left [ 0.535 \\ 0 \\ -2.54 \right ]=\left [ -2.06 \\ 1.5 \\ -0.507\right ]\)
Giving A in spherical form as
\(\bf A=-2.06\hat{\bf \rho}+1.5\hat{\bf \theta}-0.507\hat{\bf \phi}\)
As far as I know this is a standard approach. Arguably the most commonly adopted one.
In reversing the process one wouldn't therefore interpret the 2nd and third coefficients of the spherical polar form of vector A as angles. All coefficients are rectilinear displacements.
An important cross-check would be to evaluate that the vector magnitude value is consistent between the two forms - Cartesian & Spherical
Where
