Hi all, I'm hoping you can help me with a project I'm in the middle of. Hopefully this is the correct place to post. I tried searching the forums and found some relevant info but I still don't understand exactly why this isn't working.
I'm trying to light a Vf 3.00 white Osram LED mounted on a starboard with solder pads I've wired to a couple AA batteries. I'd like to use this to light a Rose encapsulated in Epoxy (for my wife from her Grandmothers funeral). The datasheet for this LED lists output at 350mA and 700mA.
I've previously built a custom LED fixture for my aquarium using fixed current drivers and detailed instructions so I'm not completely new to how to wire these up but I don't have any type of background in electronics to please bear with me and my ignorance.
I'm using 2x AA batteries in series. They both read 1.59v or thereabouts. My multimeter is not the best.
I can light a blue LED leftover from my aquarium fixture with these batteries no problem. I don't remember if the blue led is actually 3v or if it's less.
When the whites wouldn't light I thought maybe I needed more than 3 volts so I added a third AA to the series. Still nothing. I have three of these LED's so I tried another one thinking maybe I had a dud. The 2nd one wouldn't light either.
Shouldn't 4.5v light a 3V led??
I wondered if my connections were wrong so I measured for continuity to check my soldered connections and all looks good. I have a jumper wire to complete the circuit and if I disconnect it I loose continuity.
I have some resistors I was planning to use after making sure the LED's worked for me but I'm not sure which to use for the best battery life, etc. Any help on that would be great as well.
Thanks folks, appreciate any help you can offer since I'm literally "in the dark" on this one.
Greg
Greg
