Struggling to solder QFN104 (10×10 mm) package
mondo90
Joined May 16, 2025
130
I am have a lot of troubles to solder QFN104 (10×10 mm) package. At first I tried by pre-tinning the pads, adding flux on top of it, positioning the chip and heating up to 250C on a hot plate. This sort of works however I observe erratic chip behavior. For instance the voltage at the pin is 2V but at its pullup resistor 3V. I am almost sure this is due to parasitic capacitance caused by the solder flux. So next I tried without it but now the chip behaves even worse - peripherals are dead, probably the pads don't connect with the chip pins anymore.
So my questions is how to do it right? I think a lot of people propose the stencil - I gave it a try too, but first, it is super hard to position it well, second, it is even more difficult to dose the right amount of solder paste. In my case it always ends up with more than needed causing bridges between pins.
Thank you.
Ian0
Joined Aug 7, 2020
13,310
Thank you.
it almost certainly isn’t. Capacitance can’t cause a shift in DC voltage. It Is probably due to a lack of solder.
I would suggest that it might be due to too much solder on the centre pad preventing the package seating on the pads
MisterBill2
Joined Jan 23, 2018
28,502
I have hand-solderd a small number of those tiny ( (10×10 mm) package ) THAT process is farfrom cost effective!! Itis also quite a pain. What did work was to tin the traces then blot off most of the solder , then accurately position the IC and heat the legs with a VERY FINEPOINTED iron while holding the IC in place for the first few legs. Good light and a good magnifier are needed, as well as patience and skill. My approach is not suitable for any level of production work.
