- Joined Jul 18, 2013
- 30,878
I think I would have had a rethink after one, two at the most!Actually 4
Wow.The surface of the screen you see is most often part of the CRT envelope. In this case, there should be a tensioned steel band - a rimband - around the edge of the CRT near the front. The rimband is essential to assure the structural integrety of the CRT envelope against the emmense forces due to the air pressure attempting to crush it. In the event of a catastrophic event, the rimband will also reduce the range and velocity of any debrie. This is called 'integral implosion protection' by some manufacturers.
Warning: A CRT that is supposed to have a rimband but where it is missing or damaged is a serious hazard since the possibility of implosion is greatly increased and the effects of such an implosion will be more severe. However, such a situation is virtually impossible to occur on its own since the rimband is part of the mounting bracket assembly. Don't be tempted to remove the rimband for any reason unless the vacuum has been let out (in, whatever one does with a vacuum) of the CRT! Spontaneous implosion is even possible. See below for an example.
Anyway, a friend of mine decided to cut the rimband off a picture tube. I wasn't there, he told me about it. This was a 25" RCA tube he wanted to fit into a Zenith TV (don't ask me why). What happened in the next few seconds after he cut the rimband, the picture tube imploded in his face, embedding the neck and yoke assembly in the ceiling, he came out with a cut about half an inch above his right eye that needed 6 stitches to close. Had that shard of glass been half an inch lower, he would be wearing an eye patch or have a glass eye for the rest of his life.
This part is off target. HP merely wants to fit a large CRT in a cabinet that is too small, not rebuild the CRT.The only way I can see this done safely is to release the vacuum in the tube, and after rework of the metal work, restore the vacuum. I am sure there are still a lot of dusty color CRT rebuilding machines in basements! All of this must be done in a clinically clean environment!
This part is properly on target.Boy, all that without a single big word, italics, bolding, change of typeset or font size. But I am working on a small program to add "Phonetic Punctuation", invented by Victor Borge, to accommodate my dissertations! E
Oh! I thought and rethought alright! - and, unfortunately, reached four wildly different albeit equally wrong conclusionsI think I would have had a rethink after one, two at the most!
Spot on!!!Clemens/Twain said:Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities; Truth isn't
...sure wish I'd seen that 24 Hours ago!From here:
Wow
"The surface of the screen you see is most often part of the CRT envelope. In this case, there should be a tensioned steel band - a rimband - around the edge of the CRT near the front. The rimband is essential to assure the structural integrety of the CRT envelope against the emmense forces due to the air pressure attempting to crush it. In the event of a catastrophic event, the rimband will also reduce the range and velocity of any debrie. This is called 'integral implosion protection' by some manufacturers.
Anyway, a friend of mine decided to cut the rimband off a picture tube. I wasn't there, he told me about it. This was a 25" RCA tube he wanted to fit into a Zenith TV (don't ask me why). What happened in the next few seconds after he cut the rimband, the picture tube imploded in his face, embedding the neck and yoke assembly in the ceiling, he came out with a cut about half an inch above his right eye that needed 6 stitches to close. Had that shard of glass been half an inch lower, he would be wearing an eye patch or have a glass eye for the rest of his life.."
My PPE 'ensemble' (Re: the first tube) consisted merely of a safety visor --- Thus it seems, considering the glass shot that sprayed same -- 3mm of polycarbonate was all that stood between me and a 'new and exciting' life as a pencil vendorsaid:Had that shard of glass been half an inch lower, he would be wearing an eye patch or have a glass eye for the rest of his life..
...And, as I discovered to my cost, a vital structural member thereof! -- Please rest assured I've learned my lessonIt is there to assure that if the tube breaks, the glass with collapse into the tube rather than going flying out into the room.
Generally failure presents as formation of opacities -- which require removal of the bonded safety glass and all traces of adhesive followed by either re-bonding or 'tacking' the glass into place... Indeed removal of the the safety lense is the most difficult and hazardous part of the job (requiring carefully applied heat -- and a suit of 'armor')...
Maybe you should borrow Henry VIII's suit of armour from the Tower of London.
Who said it was?HP this is not funny!
Speaking of which - better watch it!You think as dumb as I type...
Seriously, where's all that coming from?Suicide is a terribly selfish act and I say negligence just as bad!
I take it you are aware that I somehow managed to survive?I come here hoping for uplifting experience not account of your gristly death!
It's not the cost but, rather, the scarcity -- by 'modern tubes' I meant relative to the TV receiver -- I doubt I can find others at any price!PS I think you care more about 300 dollar tubes than your life!
In all seriousness - Your friendship is obvious! For which I am both grateful and deeply appreciative!!!Don't hate me because I care
Indeed it is! So, on that note, if you feel there's any more to be said in this vein - lets move it to PM ...K?This is forum for discussion of electronics
You mean in my response to Aleph on this thread? If there's a 'fifty cent word' in there -- danged if I can find it?Thanks HP for making me hit the dictionary, life was getting dull.
Not this post at this point in time.You mean in my response to Aleph on this thread? If there's a 'fifty cent word' in there -- danged if I can find it?
Well, anyway, pleased to have dispelled you ennui
Best regards
HP![]()
At the time, it gave the impression of having been glued. My reading about frit seals was relatively recently.That's a new one on me? You mean a tube so constructed that adhesive functions as the frit seal!?!?--- I'm thinking an alkali silicate or some such...?
Best regards
HP
One of the big old CRT's I changed years ago, I fired a .22 dead centre from 40ft away, the >1/2" thick chunks of the face were thrown 30ft.!!On a (somewhat) related note... a CRT design must be tested for safety by dropping a 2" diameter steel ball onto the upwardly pointing face from something like three feet.
