Structural integrity of CRTs?
Hypatia's Protege
Joined Mar 1, 2015
3,228
Kind friends:
I seem to have encountered an insurmountable obstacle as regards my attempts to retrofit a vintage TV receiver with a 'modern' CRT...
Despite my best efforts I find that removal of the mounting band from CRTs having a diagonal face dimension greater than Ca. 28" (~71 cm) invariably results in instant breakage of the tube!:( --- Please understand that I have exercised every precaution by way of avoidance of 'nicking' or otherwise damaging or stressing the glass! -- In point of fact my last attempt consisted of merely 'undoing' the cinch with surgical picks sans contact or increased stress on the envelope -- Nonetheless the tube suffered instant implosion upon release of the band's tension!:mad::confused: -- Ludicrous though this may sound - I'm compelled to wonder if the band serves as some manner of structural 'member'?!?!:confused:
Having gone through four pristine NOS tubes in this fashion I'm hesitant to jeopardize my two remaining 'prospects' with any further (of my) 'bright' ideas:rolleyes: --- Any thoughts, advice or 'magic spells' will be greatly appreciated!!!:):):)
Best regards
HP
Throw us a photo (or three)!
I was doing this job before I could legally buy a beer.
What HAVE they changed? :eek:
30,885
I did that job for a few years when the CRT was in vogue but never had a problem with mounting frame, it sounds almost as if something you are mounting to is warped maybe and when reefing the mounting bolts the incident occurs?
If this is on the same TV.
Thats an expensive lesson!:eek:
Hypatia's Protege
Joined Mar 1, 2015
3,228
Thanks for the replies!:)
Owing to their fragile nature and the fact that I have only two left:(:eek: I prefer to leave them in their cartons prior to use
FWIW I found this image of similar (albeit much smaller) tubes --- notice the metal band (carrying the mounting 'ears') near the faceplate...
http://photos.prnewswire.com/prnvar/20140310/SF79743
I dunno seems the mounting band has powers unknown!:confused:
@MaxHeadRoom
I apologize that I failed to make a clear statement of my problem:oops:
Fitting of the 'new' tube to the receiver requires that I first remove its factory equipped steel band (said band being cinched 'round the 'bell' immediately back of the faceplate) unfortunately removal of said band, no mater how gently done, results in implosion of the tube at the instant the tension is released:(:mad: While I can't imagine a design employing such an 'accessory' as an ancillary structural element - such seems to be the case?:confused: --- Unless, that is, I'm missing something (wouldn't be the first time! :rolleyes:)
Best regards
HP
Hypatia's Protege
Joined Mar 1, 2015
3,228
You are not supposed to remove the band!
Do you mean to say the band is indeed a structural component as opposed to a mere breakage mitigation feature!?!? --- First unibody automobiles now ''tubes with trusses" -- Just when I thought I'd seen everything!!!:eek:
Besides, how you gonna mount it without ears?:confused:
The mounting hardware in the old receiver is rather like a large hose clamp:)
Your stubbornness must be abandoned!
Let us not confuse obdurateness with desperation...:oops:
Best regards
HP
#12
Dammit. Dictionary time again.:mad:
OK. I'm back. I did not say anything about desperation.
Your obdurateness must be abandoned.
Hypatia's Protege
Joined Mar 1, 2015
3,228
My point was that I felt you were confusing my desperation (as regards my restoration project) with obdurateness:)
Best regards
HP
#12
Best regards
HP
And...once again I am convinced you are female.
I don't give a fig about your emotions, especially when compared to your safety.
Men are like that. Get the job done safely, then, if you have time to get sloppy drunk, whine about your feelings (or what you imagine somebody might be thinking about your feelings). :rolleyes:
alfacliff
Joined Dec 13, 2013
2,458
I have been replacing crt's in tv and monitors for a lot of years, and I have never had to cut a band off. the band is for mounting, not for shipping puroses. find a way to mount the tube with the band intact.
Hypatia's Protege
Joined Mar 1, 2015
3,228
Well I've learned my lesson! -- To the tune of a barrel full of shards that used to be $300 apiece virgin NOS CRTs:(:(:(:mad::mad::mad:
Seems I'll have to...:(:confused: Trouble is, these 30" (diagonal) wide deflection angle tubes are challenging to mount in the old cabinets -- I'm 'toying' with the idea of fashioning a polycarbonate 'cradle and yoke' assembly -- either way the mounting 'ears' will have to come off... --- Nothing's ever easy!:mad::mad::mad:
Thanks for your reply!:)
Best regards
HP
38,952
It would seem apparent that the band provides structural integrity to the tube.
If you calculate the total atmospheric pressure on the face of the tube you will be amazed that any tube can survive without imploding.
I assume that when they went to large, flat-surface tubes, it was impractical to built the glass strong enough to resist this pressure so they added a metal band to provide the needed strength.
But that's just a guess.
30,885
I wonder how you came to the conclusion that the band needed removing?
The new ones should have given you an idea as they are drop in replacements usually?
#12
He just wants to fit this in a place that's too small and refused to accept that the metal band is part of the structural integrity.
