I am trying to build a thrust stand using a beam and strain gauges. I have attached the four strain gauges (350ohms) and have tested each individual one with the strain indicator box to verify that they work. My issue seems to be combining the four strain gauges into one value. I'm using the DAQ USB6009 to collect the data.
Attached you will find a picture of my schematic of the combinator and additional information regarding the strain gauges. I was getting rather weird values on Labview so I decided to use an oscilloscope to see the output.
The excitation voltage is 10V and I calculated that i should get about 2.41mv/V
When I place the oscilloscope I get values ranging from 2mv to 19mv and the values are bouncing in between. Do I at least have the correct schematic for connecting the strain gauges to the DAQ?
Any help is appreciated. Thank you in advance
