STM32 parameters explain.
lehieubk98
Joined Mar 29, 2019
27
I found out this table on the datasheet of STM32.
I knew that I_VSS is the maximum of input crurrent suply the chip can bear without any damages. Did I get that right?
Can anyone explain the parameters in this table for me?
Thank you!
danadak
Joined Mar 10, 2018
4,057
This I assume is obvious -
This is current injected into or taken out of a pin where you go outside its rails by ~ .7V and turn
on the parasitic diodes in the CMOS structure.
Regards, Dana.
BobTPH
Joined Jun 5, 2013
11,516
Not so obvious since you got it wrong. That is the max source and sink current for a single pin. For instance, if you are driving an LED.
Bob
danadak
Joined Mar 10, 2018
4,057
Got what wrong ?
Then there is this condition of injection -
The first condition led drive current as you state, the second preventing parasitic SCR
from triggering in CMOS.
Regards, Dana.
BobTPH
Joined Jun 5, 2013
11,516
Okay, that was not clear. I assumed the text below the first table was explaining what the parameters in that table meant.
Bob
