I don’t really care, but why are we trying to teach the TS how to get bad code to work instead of teaching him the proper way to code this? Sure, it’s nice to be aware of how compiler/ linker optimization can adversely affect a program, but is this the teaching situation to use?In your code before the function definition, type:
#pragma O0
In IAR, the equivalent statement is:
#pragma optimize=none
No, the proper way is the delay() function, as first mentioned in post #10.I totally agree, so the proper way is counter
#include "main.h"
#include <stdio.h>
#include "string.h"
#include "stdlib.h"
#include "stdarg.h"
/* Private variables ---------------------------------------------------------*/
DAC_HandleTypeDef hdac;
volatile unsigned long myticks=0;
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DAC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
void delay(unsigned long us)
TIM4->CR1|=TIM_CR1_CEN;
myticks=0;
while(myticks<us);
//HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_15);
TIM4->CR1&=~TIM_CR1_CEN;
void TIM4_IRQHandler(void)
myticks++;
TIM4->SR&=~TIM_SR_UIF;
int main(void)
RCC->APB1ENR|=RCC_APB1ENR_TIM4EN;
TIM4->PSC=10;
TIM4->ARR=21;
TIM4->CR1|=TIM_CR1_URS;
TIM4->DIER|=TIM_DIER_UIE;
TIM4->EGR=TIM_EGR_UG;
NVIC_EnableIRQ(TIM4_IRQn);
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_DAC_Init();
/* USER CODE BEGIN 2 */
//HAL_DAC_Start(&hdac,DAC_CHANNEL_1);
//HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,1365);
while (1)
delay(100000);
HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_14);
//HAL_Delay(500);
delay(100000);
//HAL_Delay(500);
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure the main internal regulator output voltage
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 4;
RCC_OscInitStruct.PLL.PLLN = 168;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 4;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV8;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
Error_Handler();
* @brief DAC Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN DAC_Init 0 */
/* USER CODE END DAC_Init 0 */
DAC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN DAC_Init 1 */
/* USER CODE END DAC_Init 1 */
/** DAC Initialization
hdac.Instance = DAC;
if (HAL_DAC_Init(&hdac) != HAL_OK)
Error_Handler();
/** DAC channel OUT1 config
sConfig.DAC_Trigger = DAC_TRIGGER_NONE;
sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
if (HAL_DAC_ConfigChannel(&hdac, &sConfig, DAC_CHANNEL_1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN DAC_Init 2 */
/* USER CODE END DAC_Init 2 */
* @brief GPIO Initialization Function
* @param None
* @retval None
GPIO_InitTypeDef GPIO_InitStruct = {0};
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_RESET);
/*Configure GPIO pin : PA0 */
GPIO_InitStruct.Pin = GPIO_PIN_0;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/*Configure GPIO pins : PD12 PD13 PD14 PD15 */
GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/// CODE 1
#include "main.h"
myticks=0;
while(myticks<us);
myticks++;
int main(void)
TIM4->PSC=5;
TIM4->ARR=7;
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_DAC_Init();
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000000);
// HAL_Delay(2);
delay(100);
HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000400);
// HAL_Delay(2);
delay(100);
HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000800);
// HAL_Delay(2);
delay(100);
HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000C00);
// HAL_Delay(2);
delay(100);
HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000FFF);
// HAL_Delay(2);
delay(100);
// HAL_Delay(2);
delay(100);
// HAL_Delay(2);
delay(100);
// HAL_Delay(2);
delay(100);
/* USER CODE BEGIN 3 */
* @retval None
Error_Handler();
Error_Handler();
* @param None
* @retval None
Error_Handler();
Error_Handler();
* @param None
* @retval None
* @retval None
__disable_irq();
while (1)
* @retval None
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
