OK, after changing code the LED is blinking...
thanks.
thanks.
Hi,Since your programmer is more or less a JDM programmer. Maybe you could try using this software http://www.winpic800.com/index.php?option=com_content&task=blogcategory&id=18&Itemid=64 Configure for JDM programmer. The software is not that big 1.88MB. And support alot more PICs. However I do not know this software at all. So I will not be able to offer any help at all
Gee imagine that.OK, after changing code the LED is blinking...
thanks.
Print it out and hang it right in front of your monitor.but the code is right....believe me.
Gee imagine that.
Your last step is to take this.
Next time when you ask questions follow the advice those that are more knowledgeable. Otherwise it is not worth asking the question in the first place.
Yep like I said a logical not compared to a bitwise not.I came to know it was for pin 33 only...
Take a look here http://c.comsci.us/etymology/operator/logicalnot.htmlI came to know it was for pin 33 only...
I suggest you start a thread for this one. This thread has done its job now I thinkThanks for help....
I have BLDC motor and now i want to control its speed here is the speed control which work with PPM or I2C.
please help me to write code for it.....
by Jake Hertz
by Jake Hertz
by Duane Benson
