Here is a sample and hold circuit.@#12
My mistake. No wonder the words were capitalized. Still doesn't change the face that you're self-taught *props*
You will use your whole Op amp circuit from way above (resistors and all) and feed that into the op amp (+) input.@GopherT
In my circuit, I'll have add additional resistors and capacitors for the amplified gain (otherwise the signal wouldn't be strong enough) correct?
Also, what is that transistor-looking symbol? Reminds me of a MOSFET but it clearly isn't one...
Glad to hear all is working. The LM3916 part is better suited (see post 4 of this thread). I hope it works out for you.@GopherT
Yes, a simple filter is what it is, though I have no idea why the sample-and-hold circuit is acting this way. I'll have to disregard this issue for now and keep on going.
The filter is working fine and DOT Mode is working better than ever!
Though the issue of the logarithmic scale on the LM3915 is still present (which cannot be fixed as it's part of the IC). My colleague recommended me to try with the LM3916 as its scale seems to be better for VU meters. I will try the IC tomorrow and see the difference.
In any case, my circuit is done and I will be working on the physical aspect of the project (which I will update time to time). Thank you guys for the great help!
P.S. I will post the final circuit and all once they've been finalized.
