square to sine converter
ak52
Joined Oct 15, 2014
241
Hello all,
I have assembeled the underlined below circuit on a bread board and it is working well.
How ever the output of the 4046(im not able to simulate the 4046) is a square wave which i want to convert back to a sine wave,at the moment i have used a series of low pass filters to do so.
Is there any better way to do this?
I have had my eye on the UAF42.Would the UAF42 be able to achieve this without the external RC and buffer components?
Many thanks
GopherT
Joined Nov 23, 2012
8,009
Hello all,
Many thanks
What frequency (or frequency range) are you designing for?
Alec_t
Joined Sep 17, 2013
15,119
In a similar thread to this, DDS (Direct Digital Synthesis) has been suggested. The problem with using low pass filters is that they're fine for a single input frequency, but if you want sines of various frequencies the amplitude of your wanted sine signal reduces as the input frequency increases.
ak52
Joined Oct 15, 2014
241
My frequency range is between 45Hz to 55 Hz
My center frequency is 50 Hz with a margin of 5 Hz on both sides.
The "in" in my simulation is from the secondary of a step down traansformer.The 4046 as you may have gussed is used to generate a phase locked loop which synchronizes with the "in".
I searched the DDS forums on analog devices website for a similar solution ,(even posted on it,but no response),i want to avoid use of a microcontroller for this application. Most of the DDS wave form generator chips require a controller to generate any wave form!
38,509
Why do you want to convert the signal back to a sinewave?
The 4046 phase-comparator will compare a sinewave with a square-wave.
