Spot welder schematic question
CAB55
Joined Nov 24, 2020
21
When wiring a 110V spot welder, is it acceptable to hook up both a push button and foot controller to the same electrical connectors on the circuit board so one or the other could be used? If not, what would be the best schematic scenario?
Thanks CAB55
MaxHeadRoom
Joined Jul 18, 2013
30,845
Presumably the typical N/O switch is used?
Just wire them in parallel.
The shielded foot pedal is best to avoid accidental operation.
Max.
