SPICE files
Ian0
Joined Aug 7, 2020
13,133
Since I upgraded SPICE all the transistors I have added have gone missing. I still have the downloads so I want to reinstate them. I understand that they are in a file called "standard.bjt" but SPICE has installed three such files.
Which one?
DickCappels
Joined Aug 21, 2008
10,661
Does it matter which one? Maybe the fact that you have three such folders is what is keeping SPICE (LTspice?) from finding the transistor model.
If this is LTspice, try dragging the two newest folders out of the folder that holds three at the moment. Let us know whether that works!
eetech00
Joined Jun 8, 2013
4,705
If this is LTspice version 24, it uses standard.bjt located in:
C:\Users\(username)\AppData\Local\LTspice\lib\cmp
During an "upgrade" it will overwrite the existing standard.bjt and doesn't retain any user modifications to the file.
Custom BJT models can be stored in file location (by default):
Documents/LTspice/user.bjt
LTspice will look in both standard.bjt and user.bjt for BJT model definitions.
It is not recommended to add models to standard.bjt.
