SPI interface with STM32
microcontroller60
Joined Oct 1, 2019
62
Hello everyone,
I'm using an STM32F407 Discovery board to interface with the ADS1115 ADC using SPI. The goal is to read analog voltage values from a potentiometer and transmit the results via UART to a computer.
Hardware Setup: Here's the hardware setup I'm using:
  • STM32F407 Discovery board
  • ADS1115 ADC
  • Potentiometer
  • Connected one end of the potentiometer to A0.
  • Connected the wiper (middle terminal) of the potentiometer to A1.
  • Connected the other end of the potentiometer to GND.
Code : I've configured the SPI and UART peripherals using STM32CubeMX, and I've implemented the necessary functions to communicate with the ADS1115 ADC. The code initializes SPI and UART, sends the appropriate configuration to the ADC, reads the ADC data, and transmits the results via UART. I don't get ADC data on terminal.
C:
#include "main.h"
#include "usb_host.h"
#include<stdio.h>
#include<string.h>
// ADS1115 configuration command for differential input on AIN0-AIN1
#define ADS1115_CONFIG_CMD 0x83A3 // PGA=1, Single-shot mode, AIN0-AIN1
SPI_HandleTypeDef hspi1;
UART_HandleTypeDef huart2;
uint8_t uartTxBuffer[64];
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_SPI1_Init(void);
static void MX_USART2_UART_Init(void);
void MX_USB_HOST_Process(void);
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_SPI1_Init();
  MX_USART2_UART_Init();
  MX_USB_HOST_Init();
  while (1)
         uint8_t spiTxData[] = {ADS1115_CONFIG_CMD >> 8, ADS1115_CONFIG_CMD & 0xFF};
         uint8_t spiRxData[2];
         HAL_GPIO_WritePin(CS_I2C_SPI_GPIO_Port, CS_I2C_SPI_Pin, GPIO_PIN_RESET); // Activate Chip Select
         HAL_SPI_TransmitReceive(&hspi1, spiTxData, spiRxData, sizeof(spiTxData), HAL_MAX_DELAY);
         HAL_GPIO_WritePin(CS_I2C_SPI_GPIO_Port, CS_I2C_SPI_Pin, GPIO_PIN_SET); // Deactivate Chip Select
         // Combine received data (16-bit value)
         uint16_t adcValue = (spiRxData[0] << 8) | spiRxData[1];
         // Convert to human-readable format (millivolts)
         float voltage = (adcValue * 4.096) / 32767.0;
         // Convert the voltage to a string
         snprintf((char *)uartTxBuffer, sizeof(uartTxBuffer), "ADC Value: %d, Voltage: %.2f mV\r\n", adcValue, voltage);
         // Send via UART
         HAL_UART_Transmit(&huart2, uartTxBuffer, strlen((char *)uartTxBuffer), HAL_MAX_DELAY);
         MX_USB_HOST_Process();
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
//brief SPI1 Initialization Function
  /* SPI1 parameter configuration*/
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    Error_Handler();
//brief USART2 Initialization Function
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
//brief GPIO Initialization Function
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(OTG_FS_PowerSwitchOn_GPIO_Port, OTG_FS_PowerSwitchOn_Pin, GPIO_PIN_SET);
  HAL_GPIO_WritePin(GPIOD, LD4_Pin|LD3_Pin|LD5_Pin|LD6_Pin
                          |Audio_RST_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : CS_I2C_SPI_Pin */
  GPIO_InitStruct.Pin = CS_I2C_SPI_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(CS_I2C_SPI_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : OTG_FS_PowerSwitchOn_Pin */
  GPIO_InitStruct.Pin = OTG_FS_PowerSwitchOn_Pin;
  HAL_GPIO_Init(OTG_FS_PowerSwitchOn_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : PDM_OUT_Pin */
  GPIO_InitStruct.Pin = PDM_OUT_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
  HAL_GPIO_Init(PDM_OUT_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = B1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : BOOT1_Pin */
  GPIO_InitStruct.Pin = BOOT1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(BOOT1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : CLK_IN_Pin */
  GPIO_InitStruct.Pin = CLK_IN_Pin;
  HAL_GPIO_Init(CLK_IN_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : LD4_Pin LD3_Pin LD5_Pin LD6_Pin
                           Audio_RST_Pin */
  GPIO_InitStruct.Pin = LD4_Pin|LD3_Pin|LD5_Pin|LD6_Pin
                          |Audio_RST_Pin;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pins : I2S3_MCK_Pin I2S3_SCK_Pin I2S3_SD_Pin */
  GPIO_InitStruct.Pin = I2S3_MCK_Pin|I2S3_SCK_Pin|I2S3_SD_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF6_SPI3;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  /*Configure GPIO pin : OTG_FS_OverCurrent_Pin */
  GPIO_InitStruct.Pin = OTG_FS_OverCurrent_Pin;
  HAL_GPIO_Init(OTG_FS_OverCurrent_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : MEMS_INT2_Pin */
  GPIO_InitStruct.Pin = MEMS_INT2_Pin;
  HAL_GPIO_Init(MEMS_INT2_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
I'm looking forward to hearing your thoughts and suggestions. If you've worked on a similar project or have experience with SPI interfacing, your input would be highly appreciated.
Thank you in advance for your help!
sarahMCML
Joined May 11, 2019
703
I know nothing about STM micros or this board, but unless you set Port bit A0 to an output, and set it High somewhere in your code, you are never going to read a voltage on the pot wiper. Why don't you just connect the top of the pot to V+ (3.3V or whatever the board uses), or VRef if it has one, rather than A0?
microcontroller60
Joined Oct 1, 2019
62
Why have you created another thread on the same topic? You already have these threads:
Hi there,
I appreciate your concern about the threads. I want to explain why I started a new thread. After successfully achieving my goals with UART and the inbuilt ADC, I'm now ready to tackle the next challenge: working with the SPI protocol on STM32. This new thread will help me focus specifically on SPI implementation.
microcontroller60
Joined Oct 1, 2019
62
I am using the Differential mode of the ADC (ADS1115) to read values from two different channels. In this case, it's important to set up the input channels correctly.
35,060
When developing any SW/HW project, whether simple or complex, it is important to develop good debugging techniques.
There are different approaches and techniques. The first one is to become comfortable using the IDE debugging features. At the very least, you want to be able to set breakpoints in your code and have the ability to examine the value of local and global variables.
Another feature which is highly useful for tracking data in real time. Since you are already using a UART interface, I would highly recommend that you continue to do so. Create routines so that you can output data, either as decimal or hexadecimal, to a character display. After you get this working you can move on to trouble shooting the ADC module.
microcontroller60
Joined Oct 1, 2019
62
Now, I am trying to interface an MCP3008 ADC with an STM32 microcontroller via the SPI protocol.
Connection between the MCP3008 to the STM32F407:
  • MCP3008 VDD to 3.3V on the STM32F407.
  • MCP3008 VREF to 3.3V.
  • MCP3008 AGND to ground (GND).
  • MCP3008 DGND to ground (GND).
  • MCP3008 CLK to an SPI clock pin on the STM32F407 (e.g., SPI1_CLK, PA5).
  • MCP3008 DOUT to an SPI data input pin on the STM32F407 (e.g., SPI1_MISO, PA6).
  • MCP3008 DIN to an SPI data output pin on the STM32F407 (e.g., SPI1_MOSI, PA7).
  • MCP3008 CS/SHDN to a GPIO pin on the STM32F407 (PA4).
  • MCP3008 CH0- to the analog signal.
Code :
  • I've written code to configure and communicate with the MCP3008 via SPI.
  • The code reads data from the MCP3008 channel 0 and sends it to the UART
C:
#include<stdio.h>
#include<string.h>
#include "main.h"
// Function to read ADC data from MCP3008
uint16_t MCP3008_ReadChannel(uint8_t channel);
// Custom _write function for printf redirection
int _write(int file, char *ptr, int len)
    int i;
    for (i = 0; i < len; i++)
        HAL_UART_Transmit(&huart2, (uint8_t *)&ptr[i], 1, HAL_MAX_DELAY);
    return len;
int main(void)
  HAL_Init();
  /* Configure the system clock */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_SPI1_Init();
  MX_USB_HOST_Init();
  uint16_t adcValue = 0;
  char txBuffer[50];
  while (1)
             // Read ADC value from MCP3008 on channel 0 (we can change the channel)
             adcValue = MCP3008_ReadChannel(0);
             // Format ADC value into a string
             sprintf(txBuffer, "ADC Value: %u\r\n", adcValue);
             // Transmit the formatted string over UART
             HAL_UART_Transmit(&huart2, (uint8_t *)txBuffer, strlen(txBuffer), HAL_MAX_DELAY);
             // Delay before the next conversion
             HAL_Delay(1000); // Delay for 1 second
    Error_Handler();
    Error_Handler();
  * @brief SPI1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI1_Init 0 */
  /* USER CODE END SPI1_Init 0 */
  /* USER CODE BEGIN SPI1_Init 1 */
  /* USER CODE END SPI1_Init 1 */
    Error_Handler();
  /* USER CODE BEGIN SPI1_Init 2 */
  /* USER CODE END SPI1_Init 2 */
  * @brief USART2 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
    Error_Handler();
  /* USER CODE BEGIN USART2_Init 2 */
  /* USER CODE END USART2_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_RESET);
  /*Configure GPIO pin : PA4 */
  GPIO_InitStruct.Pin = GPIO_PIN_4;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
                           Audio_RST_Pin */
                          |Audio_RST_Pin;
// Add the following function to read ADC data from MCP3008
  uint8_t txData[3];
  uint8_t rxData[3];
  // Create the command to request data from MCP3008
  txData[0] = 0x01;               // Start bit
  txData[1] = (channel << 4) | 0x80; // Single-ended mode, channel selection
  txData[2] = 0x00;               // Dummy data to clock in results
  // Lower the CS/SHDN pin to activate MCP3008
  // Transfer data over SPI
  HAL_SPI_TransmitReceive(&hspi1, txData, rxData, sizeof(txData), HAL_MAX_DELAY);
  // Raise the CS/SHDN pin to deactivate MCP3008
  // Extract and return the ADC value from the received data
  uint16_t adcValue = ((rxData[1] & 0x03) << 8) | rxData[2];
  return adcValue;
  __disable_irq();
  while (1)
  * @retval None
Issue Description:
  • When I run the code, I constantly receive an ADC value of 1023, which is the maximum value.
  • Even when I adjust the potentiometer to change the input voltage, the ADC value remains stuck at 1023.
Troubleshooting Attempts:
  • I've checked my hardware connections, including the SPI wiring, power supply, and ground connections. Everything seems fine.
  • I've reviewed the SPI configuration settings in my code and ensured they match the MCP3008 requirements.
  • I verified that I'm reading from channel 0 of the MCP3008 and made sure the potentiometer is connected to the correct channel.
Request for Assistance: I can't seem to identify the root cause of this issue. I suspect there might be a problem with the SPI communication or the MCP3008 configuration. I would greatly appreciate any suggestions, or tips from the community to help me troubleshoot and resolve this problem.
microcontroller60
Joined Oct 1, 2019
62
SPI or UART, which one do you want?
I use STM32F407 Discovery.
I use both IAR EWARM and STM32CubeIDE. What do you use?
I am working with STM32F407 Discovery board and STM32Cube IDE, I'm having trouble getting a variable ADC reading. I suspect there might be an issue with my SPI code. Could you please share your SPI code so I can compare it to mine and see if I can find the problem?
Sensacell
Joined Jun 19, 2012
3,787
Look at the actual signals with a scope- verify that what you see is what should be.
You can waste so much time looking at high level stuff when the low level stuff is wrong from the start.
