Speaker mounting
djsfantasi
Joined Apr 11, 2010
9,237
In another thread, Bertus said,
A speaker alone will not produce much sound.
When mounted on a board or box it will sound much better.
I have a speaker just mounted with a wire in my animatronic penguin. Taking Bertus' suggestion, does anyone have any recommendations on how to improve the mounting. I want most of the sound to come from the speaker front.
Kermit2
Joined Feb 5, 2010
4,162
it is the bass content that suffers most. if your program content has little to no bass then you wont notice much difference in an enclosure mounted speaker vs what you have.
djsfantasi
Joined Apr 11, 2010
9,237
Ok, there's little Bass content. It's all voice which has been shifted up so the penguin sounds cartoony. But I was wondering how to maximize the sound volume. It currently is amplified by a basic LM386 amplifier circuit and can be heard in a room if you are near the figure. I was trying to improve the quality of sound. I know it's small speaker, but as you can see there's not much room for a larger one.
Dr.killjoy
Joined Apr 28, 2013
1,196
Personal there is a huge difference between a box mounted and non box mounted speakers... I would mount it in some kind of encloser or project to better help the quality of sound and the direction.. Also look around with all the fancy design out there .They are all or mostly mounted with some kind of encloser wiether its bass or not ... I have never seen an opened air speaker on both sides ...
djsfantasi
Joined Apr 11, 2010
9,237
Would the rear be ported at all?
34,809
What you are missing is called the speaker baffle. The main purpose of the baffle and the enclosure is to prevent the backward wave from interfering and cancelling out the forward wave.
Since you are not interested in good bass response, I wouldn't worry about a port. Your main focus ought to be finding a solid flat panel to mount the speaker that faces the listener.
Since that speaker does not have mounting holes, you will have to use clamps around the rim of the speaker. They can be as simple as a three screws with washers.
Check this out for more information:
http://en.wikipedia.org/wiki/Loudspeaker_enclosure
38,504
For voice speakers you don't need much of a enclosure. A short tube would be fine (piece of plastic sewer pipe or cardboard mailing tube for example).
Fix a board (as large as possible with a suitably sized hole or holes cut in it) to those two vertical posts and glue the loudspeaker to it. Or, you could mount it onto one of the existing discs that form the chassis.
djsfantasi
Joined Apr 11, 2010
9,237
Using the vertical posts is an idea. The mouth opening is straight ahead and parallel to the plane formed by the posts.
djsfantasi
Joined Apr 11, 2010
9,237
Ahhh! Now I get it. The diagram is a cross section of the cup. Thanks, I kept seeing in perspective an object beside a cylinder inside a frame.
