Speaker cable for 3000 volts
Rufinus
Joined Apr 29, 2020
323
Hello.
I got a small power supply of a CCFL from a old printer.
I have used a voltage multiplier to get 3.000V. It is to make a experiment in vacuum. The question is, Can I use regular speaker cable (the one black and red) for that? I mean, it is made from PVC and it has a great dielectric strength but I´m not sure. I don´t care about safety reasons, the voltage is great, but the current is very weak and also I am not planning to touch the cables, what I care of is about the insulation os not enought and fail. Any advice?
Thank you
best regards
28,272
IF you are able to keep both connections well separated apart, you could use two pieces of speaker cable. But there would still be the potential shock hazard from touching them. So I do not recommend doing it that way.
dl324
Joined Mar 30, 2015
18,465
You need wire specifically designed for high voltages. Speaker wire that looks like appliance wire is probably rated for 600V or less.
