SPDT or DPDT switch?
ImWolf
Joined May 26, 2013
108
From the reading I've done already, I still don't fully grasp switches and which one I should choose for my project.
I want to activate a 3V and a 6V circuit simultaneously and have them maintained until I touch the switch again to turn these circuits both off.
It would be preferable to have as small a switch as possible, and mounting through a round (drilled) hole.
If you also know of a reliable vendor that would be great.....
Thanks,
Wolf
AlbertHall
Joined Jun 4, 2014
12,624
You need a DPST switch, which could be either a push button or toggle type.
You also need to consider how much current you will be switching.
There's some here.
ErnieM
Joined Apr 24, 2011
8,415
Ahhh, switches. Seems so simple but the devil lies in the details. Your application seems simple enough where you probably do not have to worry about voltage or current limitations.
By "touch the switch" and "small as possible" you probably want an on/off push button. Most will mount thru a round hole, and are a much lower profile than any toggle switch would be.
Switches are designated by the number of poles or separate circuits they switch, and how many throws or positions each can switch into. For two separate voltages you want a double pole switch. Since they are just going on and off a single pole is fine, though you may find that only a double pole is available. That is fine to use.
So either a double pole single throw (DPST) or a double pole double throw (DPDT) switch will work for you.
I have two go to places for parts, that being Digikey for best quality of a known part, or EBay when I am more concerned with cost and can bare not being able to get that exact same part again in the furure.
mcgyvr
Joined Oct 15, 2009
5,394
Assuming common ground you simply need one pole...
Without a schematic or more detailed information a guaranteed answer cannot be provided
Your safest bet is a double pole.. One pole for each circuit
Reloadron
Joined Jan 15, 2015
7,880
Your switch should look a little like the below image:
There are other ways but this is a common method rather than using a SPST to switch common. That said and as mentioned the devil is in the details. While you fail to mention how much current you plan to switch I assume very small low current. Cherry Switch makes a wide range of miniature switched (Toggle Type). You don't mention how you want the switch to be actuated? Toggle Switch, Lever Actuated, Push Button, Rotary or what? Like they said, the devil is in the details. Got any details?
Ron
38,423
Quite untrue when assuming a common ground.
:confused:??
Show me how you can switch a common ground to the supply without reverse voltage being applied across the 3V circuit through the 6V circuit from the common ground connection, as AH stated.
Reloadron
Joined Jan 15, 2015
7,880
Carl and Albert I will get back to you on that. Maybe a few years from now. I figure by then you guys may forget. :)
No we can't switch the common. While it can look appetizing on paper it simply will not work. :(
Now if I used a SPST switch to switch the common of a DPST relay then it would work. :)
We now resume our regular programming....
Ron
ErnieM
Joined Apr 24, 2011
8,415
:confused:??
Oops, misread both posts.
You are of course correct.
ImWolf
Joined May 26, 2013
108
Thank You all for the responses..... I should have come here sooner.
The switch I'm looking for will be attached to protrude from a plastic model spaceship project I have going. I would really like a low profile (and small form) push button switch for appearance sake.
The 3V and 6V circuits are both powered by separate battery packs. I need the 6V solely to power a small PCB chaser I built, while the 3V circuit just powers led's used for interior lighting. Both of these circuits are specific however to just the hanger deck on my space cruiser...... So until the hanger doors are open neither circuit needs to be actuated. But when the hanger interior is visible, I don't want to hit more than one switch.
Sorry my original query wasn't so descriptive as this..... I'll have to work on that. :b
ImWolf
Joined May 26, 2013
108
Here's an idea. You could make the switching automatic with two SPDT reed switches mounted inside by the door and a magnet mounted on the door.
https://en.wikipedia.org/wiki/Reed_switch
That's a cool switch I was completely ignorant of..... but still, I don't have the real estate to add much of anything inside this small model kit.
At one point I was determined to make the doors opening each a switch of sorts (2 doors completing a connection as each was slid open), but I failed thus far with a design I would be confident in lasting..... let alone working.
Reloadron
Joined Jan 15, 2015
7,880
You can look at small DPST slide switches, number of manufacturers but C&K comes to mind one of yur doors would slide the switch. There are cam type lever switches and push button types. This becomes a matter of you looking at switch designs and how they activate and what would work best or fit into your project. Nobody here can see or visualize what you have exactly and the dimensions.
Ron
ImWolf
Joined May 26, 2013
108
To make you suggestion happen Mr. Hall, I can cut thin strips of rubberized magnet material we all have on our refrigerators and glue them under the sliding doors. These strips would only be about .1" wide x 2.5" long. The stroke of each sliding door is slightly under 1", so I would then need to determine the correct switch to mount near the end point of the door action which would not be activated by the magnetic field when the doors are in the closed position.
I have no clue how to determine the magnetic force at play here, or what sensitivity rating on the switch I would be looking for. Do you think you can get me "in the ball park" with testing some switches?
Thanks,
Wolf
Reloadron
Joined Jan 15, 2015
7,880
Would be much easier to go to any home improvement or hardware store and buy some Magnetic Door and Window sensors. This way everything comes neatly packaged and ready to easily mount. Here in the US any Home Depot, Lowes or True Value Hardware should have them in stock. If the factory packaging is too large just bust the reed switches out of the plastic housing, likewise the magnets.
Ron
